dyno'd the turbo ta today
Old 10-02-2010, 09:14 PM
Sideways240sx's Avatar
Default dyno'd the turbo ta today
Finally got my turbo ta tuned today. For anyone that hasn't follwed the build threads the run down is.
Mwc everything, fab 9, drc th400, forged 370, 317 heads and a home built turbo kit with a precision 76 mm on it.
Car made 590 to the wheels between 9 and 10 psi! i am very happy with the results. The fuel pressure was falling off from 60 to 44 At these levels, and i ran out of injector. I need to get the fueling issue worked out, i believe its because i only have 1 hotwire kit powering 2 walbro 255's.
Anyways We turned it down a little to 9 psi, and the car made 576 whp @ 17 degrees of timing. There is alot left in it, and we will be pushing to atleast 15 psi in a couple weeks.
We plan on going to the track and running it @ the 576 hp next weekend, just to get a couple test passes done.
http://www.youtube.com/watch?v=4_fazgVVITU
Thanks, Chris
Old 10-02-2010, 09:18 PM
venom ws7's Avatar
Congrats man very good numbers with that drivetrain and low boost..
Just curious why didnt you go with something bigger than 76mm?
Old 10-02-2010, 09:29 PM
JAX04's Avatar
are you running E85??
Oh, lol. Great job too! sounds good.
Old 10-02-2010, 09:37 PM
110. I dont plan on street driving. the fuel pressure being to low is why we ran out of injector, not the gas. But i might of went down a country road and went through 1st and 2nd. Holy Crap, and amazingly it hooked!
Old 10-02-2010, 09:39 PM
WS6HUMMER's Avatar
Nice man, cant wait to see it go down the track.
Old 10-02-2010, 09:47 PM
How much hp did you make? your 1/8 works out to about a 10.3 or so right?
Im very curious how fast i will go. The car should be pretty light.
Thanks, Chris
Old 10-02-2010, 09:49 PM
frcefed98's Avatar
Gotta love those numbers through a TH400 and 9 inch!
Old 10-02-2010, 09:56 PM
098z28's Avatar
Nice I can't wait to get mine put together!
WS6HUMMER's Avatar
Thanks, Chris
Never put it on a dyno, I had a single 255 and the 57# injectors and was running out of fuel pressure and injector when it went 6.59 in the 1/8 & yes I agree it should have been a 10.30. I was still running 4.10 gears then too. I now have a Magnafuel 4303 external pump, sumped a metal tank, ran bigger fuel lines, 83# injectors, & 3.50 gears, I plan on going back to the track next saturday and seeing if I can see some high 9's without blowing up my still stock LS1.
Old 10-02-2010, 10:13 PM
That would be awesome man. Im hoping for high 9's in my car with a built motor. It should weigh around 3100 without a driver, i think its should be do able.
I have stock tank but two walbro 255's, -8 feed, -6 return, with a precision boost ref regulator thats good to 1000 hp they say, speed inc rails, and the 60lb injectors.. There should be enough fuel to get the car dyno'ing into the 700's and the inectors will be the park holding me back.
Old 10-02-2010, 10:25 PM
WS6HUMMER's Avatar
Yeah the injectors are small for that kind of power. Your car should easily see 9's with no problem if it only weighs 3100lbs, mine weighs 3780 with me in it. Gotta put it on a diet,lol.
Old 10-02-2010, 10:27 PM
Nitroused383's Avatar
Good job on all the work to the car, I've followed the build thread and I like your work. Could you post up a dyno graph?
Thanks!
Old 10-02-2010, 10:33 PM
BottleFedZ346's Avatar
Awesome!
I have followed this car since you started the build and cant wait to see what she clicks off @ the 1320!
Old 10-02-2010, 11:24 PM
Thanks!
I didn't even have him print it, since i will be going back, and i didn't think upper 5's was that amazing. I know the car should be upper 600's or low 700's when i can get the fuel, and the boost to where it should be. I will make sure i get a graph the next time i go there.
Thanks for all the comments guys, means alot!
Chris
Old 10-02-2010, 11:28 PM
Before we really attacked the weight, it was about 3430 wet with no driver. I now have an iron block, and cage, but we took alot of weight out. Other then lexan, the pass seat, and some vfn stuff, i dont see anyway to get anymore weight out of it.
i will make sure i get it on the scales when i go to the track.
Chris
Old 10-03-2010, 07:42 AM
JAX04's Avatar
Well, i wasnt asking for that reason, im wondering why you are loosing fuel pressure with 2 walbros at less then 600whp. thats what i was getting at, not the quality of the fuel.
Old 10-03-2010, 08:44 AM
WS6HUMMER's Avatar
Chris
Thats a lot better than I'm doing, I still have everything including AC, the only thing I pulled for weight was the passenger's side air bag, that thing is heavy! Be sure to post up some vids of your car at the track, I'm sure its gonna fly.
Old 10-03-2010, 10:13 AM
MUSTANGBRKR02's Avatar
Very nice. I am waiting on my converter to get here then I will get mine dyno'd. We have similar combo's.
What cam are you running?
Old 10-03-2010, 10:37 AM
Ptc spec'd the converter i have. It feels really good, we will see how it does on the track.
Cam was spec'd for the setup/motor. Its 232/238 .595 .605
thanks, Chris
Old 10-03-2010, 10:40 AM
The tuner called lonnies(sp) and he told him 1 power wire will do it. The regulator is boost ref, so as boost goes up the pressure tries to go up. As the pressure goes up, the pumps will draw more amps to try to pump that much. With only 1 hotwire kit lonnies said the voltage will fall into the 11's, and we will get the sympots we are getting. Its either that, or maybe a pump is on its way out, but they were both new.
Also remember, that 600hp on a th400 car is probably 700 on a t56 car. I am loosing alot of power with the th400, and 9 inch, but they usually go really fast with low number.
Quick Reply: dyno'd the turbo ta today
