Building a new kit including headers
Old 10-03-2010, 08:17 PM
Sluggish's Avatar
Default Building a new kit including headers
About a month ago I shredded the belt on my car while doing a long pull. Some of it wrapped up around my crank behind my pulley taring up my front main seal. So I drove it home leaking oil. I decided to change them cam while I had it tore down, when I got to that state I started thinking of selling the kit and building my own. If this works out the way I think I should be able to pay for everything with the money from my kit once it sells. So here I am starting from scratch. I probably would have tried this the first time around but I didn't have the tools to do the job. But now I have a Tig machine, chop saw, a grinder and the will to give it a shot here I go.
I ordered just the material to build the headers so far. Which was flanges, tubing kit, collectors and 2.5" v-bands. All 304ss at a cost of $550 shipped. Makes paying $1000-$1200 for headers not look so bad. I am probably going to use my T76 again on a t4 flange, but a friend knows a guy with a Turbonetics t6 88mm that is wanting to trade. I am waiting on more details about the turbo before I go for it.
This kit will be build very similar to KoolRayz. This is what I did today for about 2 hours.
Old 10-03-2010, 08:43 PM
BottleFedZ346's Avatar
I have always liked "forward header" setups but it looks to be a PITA to change plugs compared to a truck manifold setup......
Old 10-03-2010, 10:42 PM
Sluggish's Avatar
Yea the truck manifolds are very easy, hopefully they won't be to hard with these.
Old 10-03-2010, 11:59 PM
Nitroused383's Avatar
What did you not like about your old kit I do not understand?
Old 10-04-2010, 12:09 AM
Sluggish's Avatar
Only real thing I didn't like about it was that I couldn't run a 4" down pipe, the waste gate wasn't recirculated, and I would have had to cut it up anyway to fit a mid frame turbo.
Old 10-04-2010, 12:11 PM
JAX04's Avatar
hell yeah man, cant wait to see this come together!! best of luck!
Old 10-04-2010, 05:19 PM
Sluggish's Avatar
Another 2 hours and one header is completely mocked up. Now I need to order order more material, I used almost all of it on this one header and didn't waste one piece. I am pretty happy with it, all the spark plugs are easy to get to, so are the bolts. The slide in easily also, hopefully the don't get screwed up during welding.
Just a picture to show that you don't need a shop, garage, or even a car port to do work, but I still wish I did.
Old 10-04-2010, 05:28 PM
JAX04's Avatar
Very nice man! very nice!
Old 10-04-2010, 07:48 PM
BadgeZ28's Avatar
Nice job. I have built headers before and it takes time to get the angles and cuts right.
Old 10-04-2010, 07:59 PM
slayer performance's Avatar
props dude, looks great!
Old 10-04-2010, 09:31 PM
03supercobra's Avatar
Looking very good, looks like plenty of room for a plug change! Good job!
Old 10-04-2010, 10:22 PM
MUSTANGBRKR02's Avatar
Looks like a nice setup, just keep checking plug clearance and all of the small things.
What kind of saw is that? Is that MS or SS?
Old 10-04-2010, 11:18 PM
TX RED's Avatar
wow is this your first header ever... you got skills
Old 10-04-2010, 11:26 PM
Sluggish's Avatar
It's 304ss. That's Dewalt 14" chop saw. http://www.homedepot.com/Tools-Hardw...atalogId=10053
Yea, thanks for the compliments everyone. Like I said my main fear will be everything going back together after I weld the tubes up.
Old 10-04-2010, 11:41 PM
Josh@KY-Turbo's Avatar
Nice work Pimp.
Old 10-05-2010, 02:54 AM
berlin 83's Avatar
is that the new miller diversion 180?,If so how do you like it? im looking into buying one right now
Old 10-05-2010, 03:46 AM
Looking good sir!
Old 10-05-2010, 01:29 PM
Sluggish's Avatar
No it's a 165, it works well for the little stuff I do. But it doesn't have a lot of control, I found a company that makes a panel that lets you fine tune it but haven't done anymore reading on it. The torch head takes a little bit to get used to with the start/stop button and the heat control built in to it. I am thinking of ordering a foot pedal for it before I do the welding.
Old 10-05-2010, 02:43 PM
IT_SS's Avatar
looks great!!!
Old 10-05-2010, 08:08 PM
black98ws6ta's Avatar
Leave welding the tubes to the flange and collector last. That way you can move them around after things change alittle.
Quick Reply: Building a new kit including headers
