Best Head Gasket for FI 346 with 241 heads. MLS LS1? LS9?
Building a basic forged 346 for an FI build. Will be running an A&A intercooled T-trim setup on a C5. Would like to make 10-12 psi. This will be an 02 Ls6 block and I have a set of nice CNC'd 241 heads with 2.055. 1.57 valves. Would like to run these of course with ARP head studs. Motor will be 9.3:1 with these 66cc heads and my 11cc dished pistons.
What head gasket is best for my app. Dont really want to go o-ring'd heads or block. Want a bolt on and go solution. I would like to run these heads as I already have them. Would have them freshly surfaced. I know they aren't thick deck heads. What do you think?
I keep hearing about these LS9 head gaskets on the Zr1. These are a 7 layer MLS gasket. Can I use these on a 3.903 bore? Or should I stick with an 02+ MLS LS1 gasket?
What is the best for my app? I dont want to half *** this or do it over.
What do you all think?
Thanks
Steve
Thanks
Steve
Thanks
Steve
Thanks
Steve
ls9 for the win!!!!!!!!!!! 3.905 bore on aluminum block with half inch studs re used 5 times and 28 lbs of boost with a 101mm and stock 243 heads and zero problems after at least 20 passes.......
just make sure you retorque a few times in the proper way
Yeah, I knew about the 4.1" bore on the gasket. That was basically what I was wondering about. So I guess it looks like people are using these on a small bore setup. Using with a 241 head should be no different than a 243 as far as the gasket goes....hmm.
It does help though as 2 seconds after putting in "ls9 head gasket" into the blank space, this was given to me: https://ls1tech.com/forums/forced-in...fo-inside.html
Hope it helps.
