turbo 5.3 plugs?
Old 10-11-2010, 08:42 PM
murdock.dean's Avatar
Default turbo 5.3 plugs?
this is my current setup, Front mount Master Power T70/.96AR turbo, Pullout 5.3L LM7 8.5:1 compression, 317 heads, 02 ZO6 Cam running 10psi on daily driving and 17psi when play time comes around. I have Tr6's in it now but was woundering if it would be better running a 7 heat range plug. I like ngk's so would like to stick with them if i can. Any help would be nice, thanks.
Old 10-11-2010, 10:03 PM
LS1NOVA's Avatar
6's are good
Old 10-11-2010, 10:27 PM
keep the tr6's or go with the BR6EF?
Old 10-12-2010, 03:56 AM
Bobsmyuncle's Avatar
may i ask what your setup makes on 17 psi??? auto???
Old 10-12-2010, 07:19 AM
last dyno was at 14 psi at hit 528rwhp and 491tor at 5600 when it crack the hub in the 4l60e. now have a built turbo 400 and taking it the 23 to see what it will hit at 17psi.
Old 10-12-2010, 07:51 AM
73 nova guy's Avatar
thanks for the numbers i am on pretty much the same setup but with a different cam and an 80e.
Quick Reply: turbo 5.3 plugs?
