will my quench be to tight?
Old 10-14-2010, 08:56 AM
TermnEatr's Avatar
Default will my quench be to tight?
is a .037-.038 quench to tight for a boosted 8.9.1 cr motor?
Old 10-14-2010, 09:18 AM
TracyRR's Avatar
I hope not because mine is at .037 as well.
Old 10-14-2010, 10:07 AM
TermnEatr's Avatar
so I guess not then have you been running that quench for awhile with no problems?
Old 10-14-2010, 12:33 PM
TracyRR's Avatar
No issues at all concerning the quench. All is good and it has been 3k plus street miles and 15 plus dyno pulls. Best of luck!
Old 10-14-2010, 07:38 PM
denscor's Avatar
Not to high jack the post but when do you start losing Quench? Gasket thickness?
Old 10-14-2010, 08:02 PM
JAX04's Avatar
I too would like to know, I slapped a set of LS9s on my LQ4 with 241 heads, and a local guy told me thats probably a bad idea.
Old 10-14-2010, 08:39 PM
TermnEatr's Avatar
correct me if im wrong but i believe to get quench u first have to measure how much ur piston is in or out the hole which is usually around .007-.008 on a ls based motor then take ur compressed head gasket thickness mine is .045 and subtract which would give me .037-.038 quench ive heard between .033 and .045 is ideal but i didnt know if it was diff when it comes to a boosted motor.
Quick Reply: will my quench be to tight?
