My new custom 6 bolt aluminum block
Old 10-27-2010, 12:47 AM
CraZee ZO6's Avatar
Default My new custom 6 bolt aluminum block
building a nice 20+lb turbo 427
Here is the new custom ls6 darton sleeved 427 custom 6 bolt block
Using LSX 6 bolt heads
Callies and Weisco hardware on the way.
Shopping for a nice turbo kit either TTIix or HP twin 67
Old 10-27-2010, 01:09 AM
adam205348's Avatar
Nice looking, i am guessing ERL? I have the HP Twin Gt35r setup i am waiting to put on my vette. Which LSx heads are you going with? Ls3, Ls9, LS7?
Old 10-27-2010, 01:23 AM
CraZee ZO6's Avatar
Not ERL a custom LS6 block done by the vette doctors.
LSx heads are aftermarket GM LS7 style RACE heads.
a good watch to learn about the heads http://www.streetfire.net/video/gm-e...008_200740.htm
Old 10-27-2010, 07:28 AM
Shawn @ VA Speed's Avatar
it's an ERL block-that's for sure.
Old 10-27-2010, 08:22 AM
Big_Bird_WS6's Avatar
look in the picture right about were the timing chain goes. my ERL block and the Last customers of mine says ERL right there.
If it doesnt someone is doing something fishy
Old 10-27-2010, 08:28 AM
JAX04's Avatar
looks pretty Though know nothing about the different block, RHS, ERL, etc etc. Still looks pretty to me!!!!!
Old 10-27-2010, 09:56 AM
Both you named are breat block. but i would never spend the money ona RHS a ERL can do just the same.
Old 10-28-2010, 08:09 AM
7 Second Club
Phil99vette's Avatar
How much does a properly prepped ERL block run with all the trimmings and core charge?
Old 10-28-2010, 08:21 AM
Engine_HP's Avatar
Originally Posted by phil99vette
how much does a properly prepped erl block run with all the trimmings and core charge?
Old 10-28-2010, 08:22 AM
Phil PM sent,
also Didnt one for the Ohio boys Split a sleeve in the RHS. how does a sleev just split? i know a weak wall. ERL has put a lot fo time in there sleeves.
Hell lets talk about wieght. pretty sure everything i have read says the RHS weights more. it is only by a small amount. but wieght is wieght.
Then RHS i have extra money in the Timing chain. front and rear covers that you can only get from them. and the list goes on.
End of day i can get anything for the ERL block at a local dealer if i lose a part. RHS cant
Old 10-28-2010, 09:39 AM
7 Second Club
Phil PM sent,
The Ohio boys have a deal with ERL so I am pretty sure they run an ERL block. The Factory LS1 is about 95#, the tall deck RHS is 120. With the material they add to a LS1 block the block has to weigh more than from the factory. The ERL definitely has a place in the market.
Why is the timing chain and the front/rear covers different? AFAIK the stock deck height RHS uses the factory covers and timing chain, the tall deck requires a off the shelf unit with 2 extra links. Wayne said he used the factory covers on his RHS. The web page shows $3800 for a ERL block and the RHS is 4900 if I remember correctly. The Main area on the RHS is beefier and has larger fasteners, with the Factory aluminum blocks you should use a main girdle which runs the price up another 500 to 1000. At the end of the day they are pretty similar pieces at about the same cost once you do all the upgrades.
Old 10-28-2010, 09:49 AM
Ws6kid.'s Avatar
Nice! Turbo i assume?
Old 10-28-2010, 10:30 AM
RHS moves some of the OIL stuff around. heard this cuases problems ( honestly that is here say. i dont know first hand)
every time i have talked with RHS i need there covers. it is nice to know that the factor work on small deck. but the ERL 500 uses stock also.
and your right ERL and ohio have a deal. but i believe it was the orange ta tryed the RHS and split the sleeve. i hope one of them comes in ans states what happen. that would fix this. but i really turst my souce on this info.
Old 10-28-2010, 10:33 AM
LS1RedZ's Avatar
Looks good! Cant wait to see some results from it.
Old 10-28-2010, 05:42 PM
427's Avatar
Ohio boys have never had an RHS block in the cars, they run the ERL with great results.
RHS needs a special rear cover, it comes with it. Stock front cover bolt pattern.
RHS uses priority main oiling, no downside in that. It is also used in the Dart and LSX block.
Kurt
Old 10-28-2010, 07:57 PM
i really don't think this is the place to debate the merits of certain blocks. start another thread if you want to do that.
To the op,looks good. keep us updated on how it works out for you.
Old 10-28-2010, 08:43 PM
CraZee ZO6's Avatar
Shawn.... I thought carmen used a local machine shop but I may be confsued and this may be ERL? I will know for sure soon just waiting on a answer.
I will definetly keep everyone updated but it will be a while before we have #s with the turbo setup. Motor will be ready sometime in november then I will break her in for a month or 2 and start slapping together my turbo setup and be ready come spring time
Old 10-29-2010, 05:46 AM
sbcgenII's Avatar
Nice upgrade, your last setup looked like it ran alright from your sig on CF. What kind of diff and suspension upgrade's did you do with the 6 speed?
Old 10-29-2010, 05:58 AM
lordrazo's Avatar
nice i cant wait to get my lsx project going
Old 10-29-2010, 07:16 AM
Fireball's Avatar
not true...
Quick Reply: My new custom 6 bolt aluminum block
