Review/Refine my plans
Starting an iorn block build here soon, heres my plans this far
Undecided on CI and compression
LQ9 block half filled
callis crank
compstar or grp rods
diamond or weisco pistons
custom grind cam
main and head studed
LSA gaskets
maybe pin the mains
what else can i do to make this stronger/hold more boost? also im up for suggestions on CI, and compression, id like to hear pros/cons of each
would i benefit from aftermarket main caps and a girdle?
my goal is to be around 1000-1200 with 25-30lbs of boost
callis crank
custom grind cam
LSA gaskets
maybe pin the mains
you have alot more to research you would have to o-ring the block to safely hold that power also you need a good set of heads with a thick deck id do the main caps fo that kinda power also 25-30 pounds is a ton of boost if your combo is set up right at that boost setting you should be way over 1000.
no go on o-ringing the block, after doing a good bit of reading it seems like its not the way to go. planned on getting a good set of heads. I'm stuck on CI though, cant decide which way to go
where did you read that o-ringing the block is a bad thing??????
If ur goin over 14-15#s, o ring is almost nesacerry(sp).
if u wanna hit 4 digits,
pinned mains
o-ring(possibly even double ring)
1/2" head studs
ls9 gaskets
half filled
thts all i can think of at the moment
pinned mains
1/2" head studs
ls9 gaskets
half filled
pinned mains
1/2" head studs
ls9 gaskets
half filled
why so much boost? i know a guy that makes four digit hp on a 408 on only 12-13 lbs of boost. u dont needs crazy amounts of boost to make power u just need better flow at a lower boost plus itll last longer
Restricted User
4" stroke is NFG for the street and that power level.
Are you looking for 1000-1200 rwhp or fwhp? Are you looking to be able to go full power on pump gas or race gas?
Figure out what you are going to do about heads first. Then order the appropriate Wiseco piston to get the compression where you want it.
25#'s is about the hardest that I would push one of these blocks. If that isn't enough, then you need a bigger turbo and better induction.
Is this going to be a dyno queen or do you have a goal for the 1/4 mile? At what weight?
Stick or auto?
Stick or auto?
Stick or auto?
Stick or auto?
I'll also add im not afraid of a little nitrous if its needed.
Also wtf if NFG? it may see 200 miles a month on the street if that, mainly in the winter and early spring
Gingervitis Addict
honestly i couldnt care about dyno numbers, the car is only ran 1/8th mile, im looking at the 5.60-5.70 range on race gas. as far as heads im leaning toward the TFS as cast 225's, which i think are 66 or 64cc, mainly b/c of my budget. The car already has a th400. I plan on keeping the S480 on the car for a while. The car is currently at 3500lbs with me in it, but by the time i get this motor done it should be around 3250 or so.
Restricted User
OK, I'd build it torquey. Use a stock crank and apply the $1000 elsewhere like a good boost controller (AMS w/CO2). Use an LS6 intake or FAST. Keep the cam in the 230's duration. I'd go forward split with the that turbo. Shift by 7K RPM and 4,500-5K stall. Get the power in as fast as possible. Should work fine.
