Oil pressure at turbo?????
@ idle I have 60psi and 85psi @ 4k, so at 6500-7k I would say its an easy 90 or so. This isnt right at the turbo but in the feed line and the feed line shouldnt lose any pressure if Im right, could be wrong. Well with that said we put a restrictor in (.094) and at idle 40psi and 5k it was 60psi. So it helped but its still smoking. At idle either way its not smoking but with more rpm it will start smoking and really wont stop once you let out. Small drips of oil leaking from exhaust housing/downpipe. Took it off and exhaust wheel is dry. Brand NEW turbo and maybe 30 min of total run time on it. My drain is a -12 set-up just like Mighymouses and yes the turbo is a low mount set-up. Let me know what you guys think. I dont mind running a restrictor but dont want to starve the turbo. Could crankcase pressure be playing into this any?
I run a restrictor i made using a old nitrous jet and a modified -4an fitting and drilled a .062 hole into the nitrous jet, it helped a TON, i was blowing so much oil past the turbo when i didnt have the restrictor now its mint.
Jay
Jay
I'm running a. 070 restrictor and it only smokes a tiny bit at wot. .062 is recommended for journal bearing Turbo. I'm planning on ordering on and see if that clears up the small amount of smoke.
