what size wastegate do I need?
Old 11-04-2010, 07:04 PM
70c10's Avatar
Default what size wastegate do I need?
hey guys Im in the market for a wastegate. I have a masterpower T70 .96 on a ls1 with a turbo cam. down the road I might upgrade to a tc76. I was looking at getting a jgs 40mm gate, piston type. Will the 40 be big enough now and down the road if and when I ever upgraded the turbo.
Old 11-04-2010, 07:22 PM
Bobsmyuncle's Avatar
yes, it should be big enough, post a pic of how it is setup
Old 11-05-2010, 08:23 AM
TiAL's Avatar
how much boost do you plan to run.
Old 11-05-2010, 08:27 AM
Restricted User
98Z28CobraKiller's Avatar
Buy the 50mm
Old 11-05-2010, 09:53 AM
RealQuick's Avatar
This...
Old 11-05-2010, 10:42 AM
70c10's Avatar
Between 7 and 9 lbs its a stock bottom end
Old 11-05-2010, 11:04 AM
98TA6.0's Avatar
never a bad thing to go bigger like a 50mm but if you can properly position a 38 then that will be a cheaper alternative and work well for that boost level.
Old 11-05-2010, 11:51 AM
'Trust''s Avatar
You can never have too much wastegate.
Old 11-05-2010, 12:11 PM
TiAL's Avatar
sure you can, especially if you have high backpressure
Old 11-05-2010, 12:12 PM
TiAL's Avatar
minimum 44mm, i'd go with a 60 personally
Old 11-05-2010, 12:58 PM
98TA6.0's Avatar
i went down that road. i put CO2 pressure on top of the gate to keep it shut. 43 lbs on a 4G63 with a JGS 50mm gate.
Old 11-05-2010, 01:24 PM
XtremeDime's Avatar
I was running a tial 38mm w/8 psi last year. No issues.
Old 11-07-2010, 11:00 AM
spaz1's Avatar
I'm running a tial 38 and never had an issue.
Old 11-07-2010, 01:51 PM
ninety4three4's Avatar
It also depends on placement in the merge pipe as well. Its not all about size (no pun intended). You could have optimal placement and get away with a 38 or you could have really crappy placement and need a 44-60 just to squeak by. All depends on your plans for the kit. If you are going with a bigger charger down the road you're best off going big now and spending a little extra money to make sure you have what you need and only spend the money once. Just my input...
Old 11-08-2010, 01:03 AM
this is why i asked how it was setup. u could have a 100mm wastegate, but if its setup wring, it wont work
Old 11-08-2010, 01:39 AM
red90cobra's Avatar
so whats the proper placement for a wastegate?
Old 11-08-2010, 06:49 AM
Marcello7x's Avatar
What he said! Im in the same boat, going to run a mpt70 and planned on a 38-40mm.
Old 11-08-2010, 06:54 AM
HydroStream6's Avatar
I think you guys are actually agreeing??
I'd run larger as well. For the extra ~$100 it's good to know you'll be safe. Even a 44 or 46 can be had around $300.
Old 11-08-2010, 07:27 AM
TiAL's Avatar
needs to be put in the direct flowpath of the exhaust gas pulling from all cyl, no 90* angles
Old 11-08-2010, 07:54 AM
While this is the ideal placement, if the build layout does not permit this, they usually work effectively at a 90* angle as well.
Quick Reply: what size wastegate do I need?
