new build, 5.3 vs 6.0
old combo was a 6.0, l92 heads ( ~9.5 to 1) truck intake and 02 zo6 cam...
new motor, aluminum 5.3 , 243 heads (~10.1), 02 Z06 cam....
everything else being the same, do you think 8 psi on the 5.3 will be close to 5psi on the 6.0 ?
what turbo are you using because i was wondering this also, as i will be using a tc-78 on a LQ4, and thought about using a LM7 5.3 in hopes to have a more effiecient setup concerning the f1 turbine wheel in the tc-78, im afraid that at 364 ci, the lq4 would become inefficient and exceed 2:1 backpressure.
im just wondering if the 19~c.i. would be worth it. i already have the LQ4 but could pick up a LM7 cheap and use my 317 heads...
let me know what you think.
subscribing!!!
I Have been wondering this myself for a little while now, currently i have a LQ4 with 02 Z06 cam and 918's with a s375 76mm 1.15 AR see right at 18.5 pounds of boost in a foxbody mustang and have been 5.67 124mph and was wondering if the a smaller motor with a little more boost and being more efficient would run faster?
subscribing!!!
