what turbo might work?
Old 11-09-2010, 11:31 AM
hawk584's Avatar
Default what turbo might work?
known motor specs:
-3,956 cc 4.0 liters V 6 front engine with 94.0 mm bore, 95.0 mm stroke, 10.0 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder 1GR-FE
Old 11-09-2010, 12:50 PM
HydroStream6's Avatar
Power goals? Trans? Street or track? Budget?
Old 11-09-2010, 01:20 PM
hawk584's Avatar
for my FJ cruiser,,, no budget, it would be custom.only system really available is sts, but for wheeling i'd rather not have a turbo &piping down that far down if i happen to take the truck for a swim(yes, a snorkel would be used) ... trans is a 5-speed Electronically Controlled Automatic Transmission (ECT)... stock vehicle is rated at 260hp/271tq. the TRD supercharged model is rated i think at 304/334. i would like to throw out alittle more then the TRD.. street/wheeling
