Differences between sbc and lq4 procharger kits
I'm looking at buying a f1 procharger setup that's currently mounted on a 350 small block, but I need it to fit on an LQ4. What all would I need to worry about for swapping over? The only thing I can think of is drill new holes in the mounting plate (assuming everything is spaced correctly) and a new crank pulley / dampner. Anything else?
LS1Tech Sponsor
Page 32 has the dimensions on the sbc kits
http://shop.brutespeed.com/ATI-3LSBB...-3LSBB-001.htm
Transplant bracket dimensions.
Hopefully the above info will help you out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I'm in the same boat, standard rotation f1 w sbc brakets, basically going to have to buy the lsx hot rod kit. But they don't clear the hood in a third gen camaro.
Bob, thank you for the links, they are very helpful. The LSx transplant kits on your website, are they the cog kit or serpentine? (Cog is what is pictured by the order button, but isn't specified) What all is included with the kit? Mounting bracket, tensioner, belt, crank / blower pulleys, and mounting hardware?
Also, does this need any components from the sbc kit to work? If I was to just buy a standard rotation f1r unit, I could purchase your kit and have everything I need to mount it to my LQ4?
socal - How different does the sbc bracket look when holding it up to the lsx? It's nothing that drilling new holes and some trimming couldn't fix?
LS1Tech Sponsor
http://shop.brutespeed.com/ATI-AB007...AB007A-085.htm Bob
__________________
LS1Tech Sponsor
The brackets don't come with the pulleys, I sell those separate. The brackets do come with the mounting hardware.
I had heard that ProCharger basically started with the sbc Chevy kit when they came out with the Transplant, so I think you could drill out the bracket you have to make it work. Bob
__________________
