Procharger BOV
Procharger BOV
I'm only boosting around 8psi on my ls1. I have it located about a foot away from the d1sc. Tuner said it doesn't seem to be bypassing enough air and throwing off the MAF. Should the bov be closer to the throttle body or is there a way to check to see if the bov is working properly?
Which BOV do you have, the one that comes stock with the D1sc is crap, you need the bigger"Red" one. I have heard that people had to put two of the smaler stock ones when running a MAF set up
I have a front mount intercooler on it. And the BOV is the black aluminum one procharger sells. I guess at idle the blower is pushing too much air and it's hitting against the closed throttle body and that's throwing off the MAF. It only happens at idle or just slight throttle. When i'm just driving it it's fine.
LS1Tech Sponsor
http://shop.brutespeed.com/ATI-3FASS...-3FASS-004.htm Alum flange
http://shop.brutespeed.com/ATI-3FASS...-3FASS-008.htm Steel flange
Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
The bypass valve should be plenty large enough for your application. Do you have it dumping at atmosphere or is it recirculating? Bob
__________________
It's dumping into the atmosphere. I don't really want to go speed density now either because i've spent about a grand at the tuner already.I'm going to take my bumper off and check to see that the bpv is opening up all the way but i'm pretty sure it is. I can feel plenty of air coming out of it at idle. So the location i have the bpv is okay right?
LS1Tech Sponsor
__________________
LS1Tech Sponsor
That is perfectly fine. Bob
__________________
