Anyone make a 6 rib crank pulley larger than 6" OD?
I have a custom setup. I adapted it to use the 6 rib procharger pulley. I had run it off the main drive pulley. Boy did I lose a ton of boost going from the 7 plus diameter stock layout to the 6 inch diameter procharger unit. I don't want to go any smaller on the charger pulley. Does anyone make a larger diameter 6 rib add on crank pulley?
I wondered about using an 8 rib. That might be the way to go. I had a truck balancer and tried to cut off the 6 rib ring. It was no problem cutting around the circumference but I could not separate it from the elasticized ring. That is some amazing stuff they use to bond it. Ended up breaking the ring.
LS1Tech Sponsor
Keep in mind the 8 rib pulley will not work with the factory balancer. It needs the ATI Performance Products 918993 balancer. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
MMS use to make an oversize 6 rib crank pulley, you can find them on here used in the classifieds every now and then. Bob
__________________
LS1Tech Sponsor
They are no longer in business. A good machine shop could take your 6.0 diameter pulley and design a larger one from it. It won't be cheap though. Bob
__________________
I don't know if would work but couldn't you buy a 7.65" or 7.25" six rib crank pulley from SDCE? I thought they have the slip fit models as well that do not need to be pinned.
