AES 390ci - Now with Callies Dragonslayer crankshaft
With some success from our proven 390ci force induction engine combination we're working
with Callies on introducing Dragonslayer crankshaft as an option.
Also Callies Ultra Forged rods are available too.
Current price list - updated 5/03/2012
Original 390ci = SOLD OUT
6.0 Block
Callies Compstar H-beam rods
Callies C-Series 5140 3.825" crank
ARP main studs
New 390ci = $4695
6.0 Block
Callies Dragonslayer 3.800" crank
New 390ci = $5495
6.0 Block
Callies Ultra billet rods
New 390ci = $7395
LSX block
options available for all the above blocks
Price sounds steep however 2000hp capable with LSX block
Heres a pic of the new Ultra Billet rods, $1350 for a set of them.
Diamond pistons we use for build
6.0 Block
ARP main studs
New 390ci = $4695
6.0 Block
New 390ci = $5495
6.0 Block
New 390ci = $7395
LSX block
- Piston coating ceramic top/moly skirt $290
- Calico Coated main rod and camshaft bearings $150
- Machine block for 1/2" head studs $550
- Dowel main caps $300 (LSX already doweled)
- O ring block, Reciever grove heads, Copper head gaskets $500
- Lateral gas ports $145
No,
Compression height dictates the real estate available for the ring lands. As you shorten compression height rings are supported by less material, top ring land generally is compensated to be thinner. Thinner top land any extra heat applied to the piston (detonation) will cause the aluminum to contract.
Thicker top ring land is able to absorb the heat, less chances of cracking or affecting the structure of the piston.
This cylinder had 44% leak down
Heres a picture of our Cp Piston next to a "408" piston
$6995
GMPP LSX block
Callies dragonslayer crankshaft
CP Piston set/steel top ring set/.180 wall pins
H series bearings
ARP main studs
6.0 with same parts $5150
LSX block is $1845 upgrade
That comprises of LSX Block, we hone the cam tunnel on LSX, it does need more boring time, we can eat it for a sale if someone wants to step it up.
