boost on a stock ls1 crank??
hey guys im going to buils an ls1 for my turbo ls1.. right now im running a stock internals on a 98 wil 9 lbs of boost... im geting another ls1 from a guy i work with, i want to forge it just want to know if its worth the money to buy a forge crank... i know the 6.0 can handle about 1000hp, not sure about the ls1 crank.. thanks guys!
Wiseco and Diamond are both good pistons but neither one of them makes a stock bore piston. You will have to get the block machined to accept the larger piston. This only applies if you are doing the building of the shortblock yourself. Mahle is the only one I've found to make a stock bore forged piston.
