swapping compressor housings is it possible?
I have a TC78 and I was wondering if another compressor housing would fit on it or would I just have to buy a new turbo all together. I know of people switching out the exhaust housings so I was wondering if the compressor was the same.
supposed to be good for an added 100hp+ flow
Would love to here some feedback from anyone who has had this done as i'm considering it myself.
the T series backing plate, and comp cover will go straight on to that bearing housing. The mid frame bearing housing with the next size up shaft ,is the only difference to the tc, 60-1, hurricane, gtk, t , turbonetics T4 turbos.
and T series comp cover, with machine to inlet to suit 78mm comp wheel will be ok...
you will gain 7-10 % more flow, but lose a tiny, tiny bit of spool.
the .55 VS .7 a/r makes all the difference
there are new turbonetics models out in january...
Jose can help you @ forced inductions
