ls1 or ls2 throttle body
I was wondering if there is any advantage to running an LS2 throttle body over a LS1 throttle body on a FI vehicle other than the four bolt pattern rather than the 3 bolt ?
my goals to start are about 700 at the wheels with room to crank up the boost... the throttle body is going on a 468 big block and will be running an F1 series procharger most likely when i get everything done, but its also going in a 6000 lbs truck so i need to compromise between the low end torque and hi end power.
