Who is using the TSP 228R cam in a turbo set up?
Old 10-19-2014, 10:27 PM
Fat Jesus 808's Avatar
Ill be trying it out with a 7475 on a forged 5.3. Had it for a small nitrous build but changed directions.
Old 08-29-2017, 05:51 PM
DevilDog99TA's Avatar
Originally Posted by IMPATIENT 1
I run the 228r 112 with a pair of on3 70's a2w blowthru carbd 5.3 and love it!! I run it in my dragboat and im killing bbc powered boats with it.according to my impellor chart im making alil over 1000hp at 7300 & i turn the motor 7400 @ 18lbs...above 5500 sucka is jus insane and keeps making more power the more boost i lay to it.ive gta change impellors to a bigger cut to absorb more hp soon and ill try to lay 20lbs to it and rpm about 7200
What are the specs on your setup? Motor type, size, mods, etc? I'm running a mostly stock ls1 with the TR228 112lsa. What have you done to the motor to run 18#?
Quick Reply: Who is using the TSP 228R cam in a turbo set up?
