What makes a CCW crank so much better then a reg crank?
Is it just bearing wear ?
about to handle more power before breaking ?
would a 500hp 8k rpm engine last longer with a CCW crank ?
I know that in 2000 HP engine a CCW crank is need to deal with flex. how does it help fix the flex in the crank? would it be needed with more rpms too ?
https://ls1tech.com/forums/forced-in...rankshaft.html read this thread through, theres conversation youll find helpful.
The Counterweight balances the throw on the crankshaft, by adding weight to the middle of the crankshaft it counters the weight of the rod/piston. LS crankshafts are only 6 counterweight, less cost, less MMOI.
8,000 rpm IMO is fine with Callies 4340 crankshaft, shorter stroke will add strength. Their is a crankshaft company considering to make a US forged full counterweight 4340 LS Crankshaft, which would be a good option next to buying a billet crank.
some more info here
http://www.epi-eng.com/piston_engine...ign_issues.htm
