Need ls2 turbo advice
Well i'm palnning to make my own turbo kit. its ls2 in a fbody. I really need to know what i need to go turbo on it. right now its forged bottom end with ported ls6 heads and cam made 444whp and now looking to boost 4-7psi only what will i need.
so far i have a walbro 255 pump
if someone can tell me whats needed to be safe and make some good power. i was thinking of a t70 .96 ar, 44mm wastegate ,50mm bov. Thats all i have down now . Any input would be greatly appreciated
need info on what to get or opinions
injectors
turbo size
wastegate size
bov
intercooler size
injectors
turbo size
wastegate size
bov
intercooler size
People are griping in another thread the TC76 with .96 is clogging up about 5k rpm on 6 liters, you might want a bigger turbo. Why 4-7 psi? Run 15psi on that focker with a forged bottom, I run 15-16 on a stock bottom end so do alot of people, you say 4-7 now you will want to crank it up as soon as you do that so plan on 15.
^LOL I am starting to think that is gunna happen to me.
Do you plan on running E85? If not 60# for 4-7psi should be good. The turbo I am putting in my 6.0 is a T76 with a .96AR and A buddy down here put a T70 with a .96 and that convinced me to go turbo lol.
