317's, L92's or Aftermarket w/Procharger
I am building a 402 with F1 Procharger and looking to make around 750+ RWHP.. I have been searcing these forums for days trying to find a definitive answer, but I still cant come to a conclusion. Would a set of PRC/TEA or WCCH 317's , or L92's be adequate and reliable for 16-18PSI, and 750+ HP??? This isnt going to be a drag only car, more of a street/strip, so everytime I take it out, it wont be at high boost...I was thinking L92, but it seems the deck thickness is a huge issue. Are the 317s alot thicker than the L92 to support the boost without lifting?? Or just bite the bullet and get aftermarket??
as far as i'm concerned you can't beat the as cast trickflow's on a budget FI engine. They flow good air,almost as good as a cnc ported head and have thick decks. These will give you the least amount of issues of any heads
Thanks, what size do you recommend?? Only problem I have with Trick flows, is on the SBC and SBF heads have terrible guide problems...My brother in law has a set of Track Heat Ford heads and the valve guides are shot after 3 years..Not sure if the LS stuff is any better...
Oh yeah, next time you talk to Andy J. tell him i said hi-haven't talked to him for a while.
I will tell him next week when I go down to work on the Pro-Mod... He picked up a Pro- Street 41 ******, a little while back and we built a tunnel rammed 632 for it... It looks sweet as hell...He made it a pump gas motor at 11:1 and still put down 950+ hp and 800+ ft lbs...Thats his car to take to the local cruises...and run 8's....lol...hes crazy
