6speed Turbo cars with 4.11's question
Old 12-25-2010, 01:00 PM
My2kz28's Avatar
Default 6speed Turbo cars with 4.11's question
Ive got 4.11 gears in my moser 9 inch right now because i was using them on my forged LT1 with the F1A. Well now ive got a gen 1 ptk turbo kit for the lt1 that has the turbo mounted in front of the engine. I am going to run a MP gt45 for now (.68, 1.05) and was wondering what this car will act like with a 6speed and 4.11s..ill eventually change them out when i get more money..i was thinking it may be hard to spool it in 1st gear, but with that little .68 on there wouldnt it spool up ok? Just curious..
Old 12-25-2010, 01:04 PM
Wesmanw02's Avatar
First gear goes by in a flash with 4.11's, I really doubt you'd see full boost in 1st. Same with all the other gears too, the car goes through the gears so fast that you may spend more time shifting and less time actually building boost.
I'd swap back to 3.42's eventually, then you should have full boost even in 1st gear.
Old 12-30-2010, 11:15 AM
My2kz28's Avatar
Has anyone ran 411s with a turbo before?
Old 12-30-2010, 11:49 AM
Zombie's Avatar
You will be shifting.. A LOT!
with a .68 a/r and a small exhaust wheel you won't make much power over 5000 rpms because of back pressure.
I had 4.10s in my car when I first got it and was only running 6psi and 6spd. It sucked bad and I lost almost every street race when I had to shift from 4-5.
Old 12-30-2010, 11:50 AM
30th t/a's Avatar
I did for a short while and it was kinda fun on the street....it would rev so freaking fast, it would smack the 7000rpm rev limiter before I could shift gears..However, I would recommend 3.42's to take full advantage of the power & insane torque of the turbo's.
Old 12-30-2010, 12:40 PM
My2kz28's Avatar
I'm going to swap them..I want to snap cars off from a roll.
Old 12-30-2010, 01:35 PM
My2kz28's Avatar
Were you able to reach peak boost in each gear? How'd it drive after the swap?
Old 12-30-2010, 05:13 PM
Restricted User
98Z28CobraKiller's Avatar
Put in an auto while you're at it. sticks and turbos don't go well together.
Old 01-02-2011, 12:44 AM
Snyper's Avatar
For what its worth I have 3.54s in my car and they are very short. I want to step up to a 3.3.
Old 01-02-2011, 12:50 AM
KILLER-LS1's Avatar
i have moser 3.50 gears in mine, i dont think id want any shorter. 1st goes by realy quick especially when you lose traction
Old 01-02-2011, 10:24 AM
My2kz28's Avatar
Yea ill prolly go with 3.50's..but it cant be THAT bad driving a 6speed turbo car around...yea i realize autos are allways better for racing but this is a street car..so someone tell me that driving a 6 speed 700 whp turbo car isnt fun..i just dont see how it could be that bad. With some slicks and a 2 step arent people running pretty fast with that?
Old 01-02-2011, 11:50 AM
Ryans99ls1's Avatar
its not THAT bad. its just the fact that you have to shift which causes lose boost between shifts, so in a way your car is slowing down. in an auto you wont lose boost once its fully spooled until you lift off the gas.
so if you just like rowing gears and dont care about all out potential going as fast as you can with your setup, then stay with the 6spd. If you wanna be more consistent and have a better shot at winning races go with an auto
Old 01-02-2011, 02:25 PM
Tally TransAm's Avatar
unless you shift like a vag you dont lose boost between shifts. yes an auto will be more efficient and stay in the meat of the power band longer, but if you can keep the trans together you can go fast with a 6 speed. now i dont consider my car fast compared to a lot of FI cars but ive been luckier that most with a 6 speed at my et/power level but i dont plan on taking it out anytime soon
as for the original question, the 4.11's and 26" tires will be pretty much pointless. you wont hit full boost til probably 3rd gear and when you do itll be hard to manage cause youll have to shift so fast and run outta rpm in fourth before the race is even fun. fwiw i run 3.70's and 28" tires and think its pretty much perfect for my setup
Old 01-02-2011, 05:00 PM
My2kz28's Avatar
That's what I was wondering..I can see losing boost with slow shifts but I feel I can shift faster than most..
Old 01-02-2011, 05:18 PM
fastcars95's Avatar
Default Sorry about the HIJACK
How did you like the gears with your blower. I'm running 15lbs with my D1SC and I was thinking of swapping out my 3.42s. I have 3.90 and 4.10s to choose from. What would you recommend
Old 01-02-2011, 11:01 PM
Snyper's Avatar
Its not as fun as driving around a 503/509 car. I had more fun when I was making 503whp than when I was making 733whp. And im guessing next year ill have even less fun with another 300 or so haha
Old 01-03-2011, 01:03 AM
My2kz28's Avatar
H
The 411 gears top 4th at about 110..it was fun on the streets but sucked when trying to go fast in 5th..it'd be better with 28 inch tall tires but again who rolls around on the street with 28 inch slicks (I would if I had some haha)..I think 3.42's are going to be you're best bet tho but I'm changing my 411s for a reason..
Old 01-03-2011, 06:00 AM
XtremeDime's Avatar
Cant outshift an auto. Im going 4l80e next year.
Old 01-03-2011, 12:56 PM
youngrigo's Avatar
Out of those 2 i would go 3.90.... I have 4.10s and while they are fun they are pretty much useless! Im running 25.5 in tire too! FWIW im going with a 3.73
Old 01-03-2011, 02:20 PM
7 Second Club
NicD's Avatar
Correction, only if you don't take your foot off the floor and WOT shift then you don't lose boost between shifts. Let's see a T56 stay together at all with much of that action and turbo torque.
Quick Reply: 6speed Turbo cars with 4.11's question
