TC76 .96 on 347 ls1 and backpressure
need some real world input...
most everyone i see with backpressure issues runs the 370 not a 347.
i would like to spin 6500+ and still make power..
plan on running upto 20psi of boost at the track..
who has ran a TC76 .96a/r on stock cube LS1/6... did you hit a wall @ around 5800-6000??
i am also looking at the other thread about the bigger housing thinking of goin to the 1.32a/r with a 3.5 dp
specs.
9.4:1 347 Ls1
eagle rods
wiseco pistons 3.903 bore -11cc
stock "super crank"
Tsp LS6 heads 64cc
VA speed cam 23x/22x
trans.
4l80e with some work..
specs.
9.4:1 347 Ls1
eagle rods
stock "super crank"
Tsp LS6 heads 64cc
trans.
yea i have been over there and PMed you i think...
i tryin to keep cost down where i can but if its something i need to do i am for it..
i just dont want to lose that insta-spool with goin to the bigger housing also...
its got the F1 wheel 68mm i believe is the mm's of it...
Rotary has a 1.15ar housing for sale in this thread $125 shipped, I would jump on that for your 347.
https://ls1tech.com/forums/forced-in...vs-pt88-5.html
11 Second Truck Club
im using a T76 with .96 on a rear mount, turning +7000 rpm and still pulling at 9-10#....... motor is a 365 with 10.7 compression, 93 pump gas, and spool is instant, i think i lucked up on my waste gate placement.
I think your going to have a issue with back pressure, especially with the ported heads and cam. I ran a tc76 w.96 a/r and it pulled hard to 5k and flattened out, my motor had ported heads 221/221 cam. I would try that large a/r housing.
thanks mike...
i am thinking hard about the 1.32 ar with a 3.5 DP that should do the business..
im just cheap and dont want to pay for it
i hope i can get over 700 with this set up... inputs??
With a stalled auto you will get away with a laggier spool up, once your up in the power it's gonna stay there for the whole run.
