which bearings and head gaskets for a 370 with 16# boost?
So, im in the middle of my motor build and wanted to know of a good engine bearing kit to buy..... What is the best bearing for a 6.0 that will be boosted to about 16#.... Im using the stock crank and upgraded everything else btw.
Oh and which head gaskets?
Thanks in advance,
Dan
Thanks in advance,
Dan
8 sec potential, 12 sec slip
I'm sure there is a difference, or else GM would not have gone through all the trouble and expense of creating an all new gasket. The LS9 was engineered for boost applications, and the standard 6.2L was not.
HAving said that though, when I was building my engine, the LS9 gaskets were on national backorder, so I just proceeded with the 5 layer MLS gaskets and I've not had any problems with them so far.
Not if you are still on factory 346 short block.... [referring to ls9arp setup]
Seems like many are running coated...
How does the coating on the bearings help?
Is it to protect for longevity or for keeping temps down?
I couldn't see a coating making them "stronger" so I was curious.
