LS1 Supercharged Threaded IAT?
Old 12-28-2010, 03:54 AM
Bargain Bucket's Avatar
Default LS1 Supercharged Threaded IAT?
I'm running a Vortech 2 centri blower on my LS1 (it's a Holden Commodore from Oz - same basic setup as an LS1 Pontiac GTO). The IAT is fitted to the intake pipe after the intercooler - quite close the the TB. It's held in by a rubber grommet which has split. In an ideal world, I'd like to fit this using a more secure method and use a threaded IAT. Does anyone know of a threaded IAT with the stock harness connector and stock characteristics? I don't really want to change my tune just for this so a like for like replacement would be just perfect.
TIA.
BB
Old 12-28-2010, 03:58 AM
XtremeDime's Avatar
Syclone/Typhoon IAT sensor is threaded and plugs directly to existing harness.
Old 12-28-2010, 05:37 AM
kellysmith's Avatar
yup ^^^ post is what i use
Old 12-29-2010, 02:43 AM
Great info. Many thanks.
Old 09-02-2011, 02:10 PM
81cuttysupreme's Avatar
sorry for dumb q, but what year/model is a typhoon, cyclone?
Old 09-02-2011, 02:16 PM
68 SS's Avatar
Here ya go:
http://cgi.ebay.com/ebaymotors/Chevy...ht_4922wt_1167
Old 09-06-2011, 08:51 PM
evo462's Avatar
Dumb question...do you weld that provision on to your charge pipe? I wouldn't feel comfortable using a nut on the inside of the pipe and risk it going into the engine.
Edit...nevermind...upon further reading looks like a 3/8" npt fitting is what I need.
Old 09-06-2011, 08:59 PM
SirNemesis's Avatar
Yep, get a weld-on bung and weld it into your charge pipe.
Old 09-06-2011, 09:03 PM
11 Second Truck Club
L-EATER's Avatar
The thread size is 3/8 NPT. If your charge pipe is steel you can hack up a 3/8 pipe couple for a bung.
Old 09-07-2011, 04:52 PM
JRENIGAR's Avatar
I just threaded and tapped into the charge pipe before the tb on my kit. I used an Orileys IAT sens that changed over from one of these two part #'s Gm 25036751 or Wells SU127.
Quick Reply: LS1 Supercharged Threaded IAT?
