STS turbo LT1 vs LS1 differences
here"s mine. the lt1 dont a have the abs block so the pipe comes up through that way. Dont let that be the deal breaker, If your getting a great price you can call sts and just order the pipe they you need there pricing is pretty good for replacement parts.
Highly reccomended to upgrade to larger injectors.... Pretty much a must! Run a min. of 42lb injectors. You will end up running out of injector/fuel and burn a hole in something!
Run a search on STS in this forum and you should find everything needed to do a safe install.
