Twin Turbo CTS-V Build
Old 01-30-2011, 09:54 AM
V-seriesTech's Avatar
gonna go ahead and call this a reliable 750+ hp build lol... tight work,..nice to see someone go turbo anything in these cars.
Old 01-30-2011, 09:56 AM
Tig
Tig's Avatar
BAD-***
This is going to be good. Like said by Hi V, not to often if ever you see a Twin V.
Motor looks killer. Nice job man.
Subd
Old 07-24-2011, 08:54 AM
cadivette's Avatar
Finally started the car last night!!!! At first it didn't want to kick over and found that the injectors were gummed up from sitting. Good thing I just got my new 80lb. injectors on Thursday. Popped them in, made a few changes to the tune, and it fired right off. After running about 5 minutes, one of the injector o-rings started leaking, so I'll have to fix that before it runs again. No biggie.
Here are the latest pics......
http://s1199.photobucket.com/albums/...view=slideshow
Low quality cell phone video (it's all I had at the time).....
http://s1199.photobucket.com/albums/...irststart1.mp4
Old 07-24-2011, 11:30 AM
TracyRR's Avatar
Wow, very well documented. I wish i had the patience to take that many pics on my projects. Great job on your car, very well done!
Old 07-24-2011, 12:50 PM
Professor_speed's Avatar
do you have more pictures of the actual turbo system? under car shots? whats your plan for the glass rear end under these cars?
Old 07-24-2011, 02:31 PM
cadivette's Avatar
I'll take some more pics before I get it all buttoned up.
For the rear I already built a diff girdle that should help. I don't drag the car, maybe an occasional roll race or a run on the freeway, but no 5K clutch dumps. Here's the girdle....
Old 11-06-2011, 08:00 AM
cadivette's Avatar
The car is pretty much finished and I've been driving it for about 1500 miles. Changed out the break in oil after a few hours of run time, then changed the conventional 10W40 out around 1000 miles to synthetic 5W40. No worries from what came out with the drains, very little metal particles on the magnetic drain plug. The tune is fairly conservative running pretty rich (10.8 to 1 AFR) at WOT and 14.7 to 1 AFR under cruise and light throttle. Conservative spark map with no knock retard at all. There is a some power left on the table with a more agressive tune. I'll work on that once winter passes.
Here is the last update to the build slideshow.....
Differential girdle finished.....
I had to pull the exhaust off last week to do some work to it and couldn't resist starting it up.....
http://www.youtube.com/watch?v=Nu28JReuaQg
This one is a quick test run when my neighbor talked me into taking him for a drive....
http://www.youtube.com/watch?v=j_zDwt8TPcY
That drive was on a rough narrow back road, so I didn't get too crazy.
Enjoy!
Old 11-06-2011, 10:02 PM
3xbrowncutty's Avatar
awesome!
Old 11-07-2011, 06:25 AM
Moter's Avatar
Sweet build! Great job on documentation.
Old 06-18-2014, 06:36 PM
LS1Tech Editor
Marcus S's Avatar
Awesome build. Posted to the LS1Tech blog here!
Old 06-18-2014, 09:37 PM
coltboostin's Avatar
Is this you losing to a small turbo'd DSM? I am assuming no but its a black TT-V...so I have to ask
Old 06-18-2014, 10:12 PM
  #32
H8R
H8R's Avatar
HX40 isn't that small for a dsm and awd kicks *** : )
I've seen cars make over 600 whp with this turbo, at about 35 psi IIRC.
Old 06-19-2014, 06:58 AM
  #33
I consider it a Shh-medium turbo.
But then again, I had a 74mm on my 4G63.
Old 06-19-2014, 08:11 AM
  #34
Blackpanther99's Avatar
Thing is gonna be insane.
Old 06-19-2014, 09:35 AM
  #35
H8R
H8R's Avatar
I hear ya, had a FP37R on mine. : )
Quick Reply: Twin Turbo CTS-V Build
