LS2/LS6 Cam Vs. Turbo Cam? How much diffrence?
Old 12-31-2010, 07:17 PM
Blownz28man's Avatar
Default LS2/LS6 Cam Vs. Turbo Cam? How much diffrence?
Is there really a lot of power between the two cams? I know the LS2 cam is close to the LS6 cam. And the Ls6 cam is good for boost. But honestly how much power can be made in a good forced induction camshaft vs. a LS6/Ls2 cam? I've got a ls2 with a garret T76 Turbo and kinda would like more power. Maybe 317 heads and a cam+ boost and a better tune. Thanks
Old 12-31-2010, 09:38 PM
yelo04goat's Avatar
well i hope its worth the money.. cuz i bought a turbo cam from shawn @ VA speed...
from what i hear its worth it... i got my fingers crossed...
in for info
Old 12-31-2010, 09:46 PM
Yea just keep us posted. What are the specs do you know? Honestly I miss having a cammed car. Now that I have a turbo car it sounds stock w/ exhaust intill you put your foot in it.
Old 12-31-2010, 11:47 PM
yelo04goat's Avatar
its back home im out on deployment right now... got a whole motor build waitng on me when i get back should be fun...
Old 01-03-2011, 09:23 PM
Anyone?
Old 01-04-2011, 07:01 PM
jks67ss396's Avatar
id like to know the same thing
Old 01-04-2011, 07:06 PM
IT_SS's Avatar
well, where do you want your power? Desired Red line? I scored an 02 Z06 cam for $40, I've no intentions on spinning past 6500 and want to maintain stock idle/exhaust note
Old 01-04-2011, 07:14 PM
Restricted User
98Z28CobraKiller's Avatar
The OVER SIMPLIFIED way to look at it is in NA terms. How much more power does a stock LS1 with a TR224 cam make than one with an LS6 cam? What ever that number is, you multiply it by 2 @ 15 psi. This generally applies until you get into a lobe overlap situation. Then back pressure starts coming into play and it gets more complicated.
Take my setup for example, I would probably have to run an extra 5 psi of boost if I ran an LS6 cam to run the number that I do with my Stage 2 Livernois cam. I dreamed up what I wanted and then started looking around to see who had something on the shelf similar to what I wanted. The Livernois was the closest.
Quick Reply: LS2/LS6 Cam Vs. Turbo Cam? How much diffrence?
