Turbo trade?!? Precision 78mm
Old 01-04-2011, 07:27 PM
020NN20's Avatar
Default Turbo trade?!? Precision 78mm
I know this should probably go in the classifieds but I figured i'd be better off here.....I have a Precision 78mm turbo, .96ar, 3" DP. I have read a lot of threads that this turbo will hurt my top end and bog with my engine combination....was wondering if anyone wanted to trade or work out a deal for a turbo with a larger hotside which would benefit me....My turbo has literally 3 weeks of run time on it, went to the track twice for a total of 9 runs. It ran incredibly strong at 10 lbs. but I was only on a run tune and was not at the time able to turn up the boost....i will eventually be running around 18psi on a race tune and am told by alot of people on this forum(and others) that The turbo at 15 psi will run out of breathe and back up....SO....If anyone has a turbo, preferably larger as my cubes and compression can support a larger turbo, but a 76 with a 1.32 or so hotside will also be considered. Let me know. Thanks
Dennis
020NN20 is offline
Old 01-04-2011, 09:11 PM
HydroStream6's Avatar
I'd turn up your setup and see how it reacts before you change your hardware. It might make all the power you want/need.
HydroStream6 is offline
Old 01-04-2011, 09:57 PM
rotary1307cc's Avatar
what turbine? the 75?
rotary1307cc is offline
Old 01-04-2011, 11:08 PM
MaxxMitchell's Avatar
What is your set up? How much power are you looking for?
MaxxMitchell is offline
Old 01-05-2011, 02:54 AM
yelo04goat's Avatar
x2 on the turn it up and see...
never know you might have the golden setup and it run perfectly fine
yelo04goat is offline
Old 01-05-2011, 04:01 AM
CarsandWomen's Avatar
yup, %100.
CarsandWomen is offline
Quick Reply: Turbo trade?!? Precision 78mm
