turbo/ fuel pump ?
turbo/ fuel pump ?
i have a stock ls6 that im gonna turbo in a few months...im funning the ebay frontmount kit with a .60 1.0 a/r turbo on 7psi...can i manage to run the stock fuel pump....do i need to drop the tank for a new one or are there other options....on a budget soooo $500 pumps are outta the question...what can i do...need to run about 55-60 lbs/hr on the injectors too
Bosch 044 is the best pump IMHO. The pump only cost $225, if not cheaper. You can do twin Walbro HP's for $100-$125 ea. But I rather just run the Bosch. The bosch is good for 700hp. I made close to 700whp on my import at 38psi of boost. The pump is the size of a coke can lol I'm in the middle of installing my turbo kit and this is the pump I'm going with. Stay away from the aeromotive 1000 pump. It doesn't flow as much as the bosch.
http://www.jayracing.com/index.php?m...&products_id=1
