SC car gearing
Old 01-08-2011, 02:33 PM
blownbird355's Avatar
Default SC car gearing
I'm running a 4.10 gear 4l60e car. Gear was in the rear is why I have it. Would switching to a higher ratio keep car in boost longer and be quicker? Trying to see what effects higher gears have on SC cars.
Old 01-16-2011, 11:10 PM
Wow nobody
Old 01-16-2011, 11:18 PM
'Trust''s Avatar
I wouldn't do more than 3.73's on a S/C car. I think 3.55's would be money. With the power you can make, you'll be out of your 1:1 before the traps.
Old 01-17-2011, 08:45 AM
Packy's Avatar
I am actually stepping down from 3.73's to 3.08's soon because I have been running out of gear about 100-200 feet before the traps and I only have three gears so pedaling or bouncing off the limiter is all I can do. I would think that some 3.42's or 3.55's will work out for you really well.
Old 01-17-2011, 09:00 AM
joblo1978's Avatar
Wow, that's a big jump down. What about just running a taller tire?
Old 01-17-2011, 09:32 AM
Packy's Avatar
I am already running 27" tires and am also in need of some more streetability out of the car. I am also looking into the future for when I switch from my P1SC to an F1A. Right now cruising at 60-65mph is around 3200-3500 rpms.
Old 01-17-2011, 09:42 AM
joblo1978's Avatar
Got it.
I just went to 4.10's with mine. Lot's of fun. It is a stick, and I make max boost very quickly.
Old 01-17-2011, 09:50 AM
Taubr Unit's Avatar
I got 4.11's with a 30" tire, well find out in a few months how it works
Old 01-17-2011, 10:09 AM
LS1RedZ's Avatar
Im running a 3:73 with a 28" tire. Im a 6 speed tho. Id say run a 3.55 like Trust mentioned.
Old 01-21-2011, 12:01 PM
My carrier is a 4 series so the highest I could go with it is 3.73 without buying new carrier.
Old 01-21-2011, 06:09 PM
black01_WS6's Avatar
Kind of depends on how much power you are making. If making less than 10#s I would run 3.73s. If a larger motor or more boost you would need a lower gear.
Also like others said tire size can help or hurt depending on size.
Old 01-21-2011, 09:01 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
My Camaro had 370 gears with 28" tall tires, which was a good combination for track use running low nines. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
