00 SS, T6 Y2k 88mm Build.
Old 01-10-2011, 07:36 PM
AGTischer's Avatar
Default 00 SS, T6 Y2k 88mm Build.
New here, this is my first post on LS1 tech . Thought everyone would be interested to see another turbo build and shoot out some comments and thoughts.
2000 SS with a Stock displacement LS2 (364" aluminum)
Stock Crank
H-beam rods and forged pistons
AFR 205's milled for 11:1 compression
Custom ground Cam
TH-350 w/ brake
Moser 9" w/ 3.50 gears
10 pt cage
car weighs 3300# w/ me in it.
275 Hoosier radials
Running on E85
Just got in my Spoolin Performance headers and crossover
Running a Turbonetics Y2K 88mm turbo
Tial 60mm gate
A2A intercooler (Race Class rules)
Let me know what y'all think!
Adam
Old 01-10-2011, 07:42 PM
Busy Mopper's Avatar
seems like a high compression?
Old 01-10-2011, 07:45 PM
yelo04goat's Avatar
nice
looks good and slow
Old 01-10-2011, 09:15 PM
DeltaT's Avatar
That should be a rocket - have fun! That E85 is killer stuff if you can get it nearby.
Jim
Old 01-10-2011, 09:37 PM
Woody73z's Avatar
After wasting my time reading your thread you really shouldn't be commenting on anyone's turbo build. 11 to 1 will be the limit i think with E85.
Old 01-10-2011, 10:47 PM
mike13's Avatar
When considering running E85 does it affect what parts you use in the build? I know you need to take into consideration injectors, fuel pump, etc. How about compression ratio, turbo, etc?
Old 01-11-2011, 12:15 AM
hahah ya since u got **** to post about like saying 'i think' y u mad????
Old 01-11-2011, 01:38 AM
Chris81's Avatar
To be honest, Adam bought the car with the motor like that in it and we ran a little nitrous on it last year (6.90's @ 101 in the 1/8 @ 6000 FT DA's) and decided to try out the turbo on this motor. Is it the typical setup you might see in a turbo motor? NO, but we are going to find out if it will stay together or not..LOL It only has 4 bolt heads, standard studs and cometic gaskets so we will be easy on the tuneup (i'm the tuner). We would love to see some 5's in the 1/8 out of this thing at our altitude.
IMO you can run more compression on a E85 motor (street) and not worry about getting into trouble but on a race type deal (what we will be doing with the car) you would be fine with a higher compression with gasoline as long as the tuner has his crap together and the car was setup right. I like the idea of more usable NA power and being able to make more power on less boost with a little more compression. The turbo would really need to be picked out for the application, regardless of the fuel used. I'm no expert, just my opinion.
Old 01-11-2011, 11:34 AM
Woody73z's Avatar
I think because we havent done it yet.. just going by what some people say is the sweet spot with e85. My stock long block 6.0 went 6.50's with 10 to 1 comp and a y2k 80mm on e85.
Old 01-11-2011, 01:39 PM
AutomagicLS1's Avatar
that thing's gonna MTFO
Old 01-11-2011, 02:01 PM
Louis at GSS's Avatar
I love E85
Get a tester! Test your fuel before you turn up the wick on it!
Old 01-11-2011, 03:58 PM
turbo iroc's Avatar
any close up pics of the turbo? i have a t6 88mm turbonetics turbo ill be using on my 402 ci lq9 and i think i have an older version; it has a garrett echaust housing 1.08 ar and its all cast iron except for the comp housing sucker weighs like 40lbs!
Old 01-11-2011, 04:21 PM
Chris81's Avatar
Originally Posted by Louis at GSS
I love E85
No doubt, we will definitely keep a good eye on it. The only bad thing is the closest E85 is like 4 hours from us, so we have to stockpile it..
Old 01-11-2011, 04:31 PM
Chris81's Avatar
I have a couple of decent iphone pics of it, none of the exhaust side though (i'm working out of town currently)
Old 01-11-2011, 06:04 PM
Fb0dy0nly's Avatar
Dang, I've got taco neck now from lookin at those pics for too long...
haha keep um coming as it gets all finished up
BTW, I have e85 2 miles down the road...whoot whoot
Ill eventually take use of that
Old 01-11-2011, 06:33 PM
Woody73z's Avatar
I love E85
Thats funny you say that... we ran e85 last year in my car and my friends turbo mustang we bought a tester and it tested out to like 95% ethanol. We just decided to mix it down with c16 i wasnt expecting 95% though.
Old 01-11-2011, 07:46 PM
turbo iroc's Avatar
ok yours looks a little different than mine. is that horn on the compressor part of the housing or is it detachable? heres mine i, i did some measuring and it specs out as 88mm comp inducer and 89 on the exhaust exducer.
Attached Thumbnails 00 SS, T6 Y2k 88mm Build.-1304.jpg   00 SS, T6 Y2k 88mm Build.-1305.jpg
Old 01-11-2011, 09:51 PM
Woody73z's Avatar
It comes off... I have a y2k 80 we both bought these turbos from a friend of ours that had them laying around. I think they are 6 or 7 years old. I know they have the bigger turbine wheel and the .96 ar exhaust housing. I think they made 2 or 3 versions of the y2k turbos. Hell they still have the stickers on the compressor covers before they engraved them.
Old 01-12-2011, 12:04 AM
ReApEr75's Avatar
Looks like Spoolin Perf. makes a nice crossover/hot side. Would like to see this thing move out as well, especially on E85.
Old 01-12-2011, 08:51 AM
AGTischer's Avatar
We will be working on the car diligently over the next couple of months trying to get ready for our season to start in April. I will keep the pictures and updates come as we make progress.
Adam
Quick Reply: 00 SS, T6 Y2k 88mm Build.
