D1 procharger with 3.4 pulley... How much boost will it make? and what size injectors - LS1TECH
Thread Tools Search this Thread
Old 01-30-2011, 11:47 PM   #1
firehawk68mcleod's Avatar
Default D1 procharger with 3.4 pulley... How much boost will it make? and what size injectors
Im building an ls2 . wiseco -11cc pistons , callies rods, stock stroke. super vic intake and elbow ,90mm tb, ported 317 heads. and this is the cam that was recommended to me 224/228 .581/.588 114 LSA. What kinda boost levels will i see with my D1 procharger with a 3.4 pulley. and intercooler set up.... also what injectors should i run?80, 60lb ? thanks
firehawk68mcleod is offline   Reply With Quote
Old 01-31-2011, 12:33 AM   #2
Aster's Avatar
I would guess close to 18psi. For injectors don't forget the power lost for turning the blower. You will need the extra fuel, go for the 80's. S/C cars have a way of maxing out the 60's in the mid/upper 700's.
Aster is offline   Reply With Quote
Old 01-31-2011, 12:40 AM   #3
Quote:
SO im going to make tons of power probably...? im putting this engine in my 68 camaro with a six speed.. i was hoping streetable... Do u think i could use a bigger cam or go with this one?
Old 01-31-2011, 11:05 AM   #4
Im running the 3.4 pulley and seeing around 16psi. You might see more, who knows. I would definitely step up to some 80lb injectors. Mine are tapped out and I made 780rwhp, I just got my 95s in. If you dont have a cam already or have the money to switch I would go with a Brutespeed (EPP) blower cam. On the power question, yes your gonna make some serious power with that pulley and setup.
LS1RedZ is offline   Reply With Quote
Old 01-31-2011, 11:45 AM   #5
Contrarian™
'Trust''s Avatar
I made 19 psi on that pulley, 75lb injectors were at 9X% so I went with 95's. Made 808rwhp through a 4L60E with that.
'Trust' is offline   Reply With Quote
Old 01-31-2011, 12:07 PM   #6
fatmat80's Avatar
LS1redz I have a similar cam to the op? How much power do you think could be gained from switching from a 224 ish cam to a brute speed blower cam? Sorry for the partial hijack..
On topic I think you will see from 14-18 psi with the pars listed above.
fatmat80 is offline   Reply With Quote
Old 01-31-2011, 01:09 PM   #7
Quote:
Whats your engine set up.... im putting this in my 68 camaro with a six speed ... just for laughs... what kinda gas mileage did you get while you kept your foot out of it/ thanks
Old 01-31-2011, 01:39 PM   #8
Tirefire's Avatar
Where did everyone buy their 95 lbs injectors? Also this might be a stupid question but are they supposed to be low impedance injectors??
Tirefire is offline   Reply With Quote
Old 01-31-2011, 02:14 PM   #9
8 sec potential, 12 sec slip
ChevyChad's Avatar
Stock injectors are high impedance. If you buy low impedance injectors, you will need a driver box for your computer to be able to control them.
ChevyChad is offline   Reply With Quote
Old 01-31-2011, 02:38 PM   #10
Quote:
What size injectors are you running... do you think 9-1 compression is ideal for d-1 3.4 pulley at 15-18 lbs. some say its low for our prochargers where its more idea for turbo set ups?
Old 01-31-2011, 02:41 PM   #11
ChevyChad's Avatar
I am running high impedance 80# injectors. I'd say 9.0:1 is a very good spot to be with 18psi from a procharger for sure if you are using pump gas & meth.
Old 01-31-2011, 02:50 PM   #12
Also what fuel system are you running
Old 01-31-2011, 02:57 PM   #13
pdasterly's Avatar
similar setup, 9.1 cr D1SC with 3.4 pulley, ls9 cam. waiting for new numbers. fic 80lb injectors, dual walbro in-tank with hot wire. I also have a boost a pump but havent installed yet.
old numbers - P1SC 12psi 550rwhp@5500 rpm
pdasterly is offline   Reply With Quote
Old 01-31-2011, 03:13 PM   #14
Contrarian™
'Trust''s Avatar
Quote:
9.7:1 396ci LS1
Diamond -15.9cc Pistons
Eagle H-Beam Rods
Lunati 4.125" Crankshaft
Victor Jr. Intake Manifold
IntakeElbows.com Elbow
NX 90mm Throttle Body
AFR 205cc 66cc Cylinder Heads
XP Custom Blower Cam
Kooks 1 7/8" Coated Headers
It made the same power on the LS6 intake, but the Vic. Jr carried it an extra 400rpm.
As far as injectors, mine were low impedance Precision's, 95lbs/hr, Acceleronics Driver box.
Then the ProCharger, no really sure on mileage, probably averaged 15-18. You'll do better in a 6 speed!
Old 01-31-2011, 03:16 PM   #15
ChevyChad's Avatar
Dual in-tank 255 walbros (second one boost activated), -8AN feed, -6 return, boost referenced FPR, speec inc rails. supplemented by an alkycontrol single nozzle meth kit..
Check my garage by my avatar for full details about my car.
Old 01-31-2011, 04:27 PM   #16
Quote:
Give Jon a call at (FIC) Fuel Injector Connection off of here. Got my 95lb High Impedance from him.
Old 02-01-2011, 03:34 PM   #17
pdasterly's Avatar
Quote:
Same here, I use them for all my builds.
Old 02-01-2011, 03:43 PM   #18
Quote:
how much do the run
Old 02-01-2011, 05:20 PM   #19
what cam specs did you run
Old 02-01-2011, 07:14 PM   #20
Tirefire's Avatar
I did he advise me that to get the horsepower I want (800 rwhp) he could either bore my 60 lbs injectors to 80 lbs or I could buy a set of 80 lbs. It seems 80 lbs aren't cutting it though!!
Related Topics
Thread Thread Starter Forum Replies Last Post
Boosted 402, Bench guesses? BigBadWhitey Dyno Guesses & Bench Racing Forum 3 05-06-2015 04:13 PM
How much boost will a 7" crank pulley and a 3.4" pulley make on a D1 sc procharger firehawk68mcleod Forced Induction 24 05-26-2013 02:23 AM
At which point should i upgrade to the Procharger BIG red race valve and why? firehawk68mcleod Forced Induction 32 04-27-2011 11:15 AM
Ls2 402 d-1 procharged power? firehawk68mcleod Generation IV Internal Engine 10 12-24-2010 10:43 AM
Tags
34, 98, boost, d1, gas, gt23, injectors, ls1, nitrous, p1sc, procharger, pulley, pump, put, run, size, supercharger, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
