APS turbo upgrade
Old 04-13-2011, 08:19 AM
FirebirdSS's Avatar
Default APS turbo upgrade
I talked to dkt performance Big bird last night and he sent me this picture.
aps with a pte 6262 Ball Bearing
Old 04-13-2011, 08:23 AM
wildta's Avatar
Holy ! That is sweet. what is the hp rating on those ?
Old 04-13-2011, 08:25 AM
FirebirdSS's Avatar
a lot... over 1000. They are slightly bigger then gt35s i believe.
Old 04-13-2011, 08:47 AM
wildta's Avatar
I have a stage 2 extreme kit and I don't think my turbos are close to the size of these ones. I think you can get way more than 1000hp to wheels ? ...... 1200hp?
Also what are the drilled holes for on the cold side ?
Can you also pm me a price.
Thanks Warren
Old 04-13-2011, 08:54 AM
FirebirdSS's Avatar
Thanks Warren
I have seen over 1000 at the wheels with gt35s, these will do more. 1200 i would say wouldnt be out of the question but it will depend on the motor setup.
Its a ported shroud/anti-surge housing.
Old 04-13-2011, 09:00 AM
bondosgto's Avatar
link for the upgrade
Old 04-13-2011, 09:05 AM
Toxic-Evo's Avatar
You have to call or email for upgrade.
Devin@dktperformamce.com
( mods delete that if you have to, but no sponsor has a ball bearing upgrade for APS. So I hope that didnt break rules)
Old 04-13-2011, 10:39 AM
02blackbeauty19's Avatar
Is anything done to the turbine housings or are they stock?
Old 04-13-2011, 11:09 AM
Toxic-Evo's Avatar
They are custom turbine housings. DKT linked up with Precision to have custom housings made. I got a per order and my friend with a C5 APS kit got on pre order. DKT says they will fit C5, F-Body kits for sure. They are looking for guys with GTO & G8 to test fit. But idk anyone with those, so..........
Old 04-13-2011, 12:50 PM
I gotcha. If they were the same price as what he quoted me before, they were high, but do give guys a ball bearing replacement if thats what they are after. As Im sure you know, there are already journal bearing replacements that flow more than the GT35's.
Im looking for forward to the results.
Old 04-13-2011, 06:06 PM
beavis's Avatar
These bad boys will be going on my 402 that HKE is building me!
Old 04-13-2011, 06:36 PM
What do these flow in lb./min. ?
Old 04-13-2011, 09:21 PM
Toxic-Evo's Avatar
i believe 68. but then again i have heard 75 before. so......... i say some where between there. lol.
Old 04-13-2011, 11:06 PM
93camaro_zzz's Avatar
LG upgrades, which is still a 20g turbo, flow 70lbs/min. So that's not very good if these flow 68, yet they are bigger than a GT35R. Am I missing something?
Old 04-14-2011, 01:05 AM
Toxic-Evo's Avatar
^^^^ thank god i dont sell turbos. lol. i dont know. i was just swinging in the dark. i cant find info on the Precision site. i will have to Call Devin tomorrow. but on Garretts site it says the GTX35( which the 6262 had billet wheel also) flows 75lb/min. which if that is the case, that should be like 750 a turbo. lol. i hope i did that math right. lol.
Blackbeauty
I dont know. I know that i got ducked over on the first APS turbos, and bought extrems from APS. both journal bearings. both went bad. had a State side company rebuild the extreme(name not given but well known), and it went ****. i am tired of spending money on journal bearing turbos. so even if thes make the smae power as LG turbos and cost more. i really dont care. i love the fact there is a ball bearing option. requires less oil. spins more freely between gears. and Precision knows there ****. tons on sponsors on here run them. i had no problem getting on the preorder list.
sorry i will end my rant. just putting my tech advice about my experiance with journal turbos
Old 04-14-2011, 11:00 AM
I think the 6262 turbo has a 62mm compressor inducer with a 82mm exducer. The upgrade journal bearing turbos out there have a 60mm compressor inducer and can have an 82mm exducer. The PTE turbos are probably good for about 20-30 more HP on paper but do give the nice ball-bearing option.
I'm really looking forward to the results andits good someone else is making headway on good replacements. Options are nice to have.
Old 04-14-2011, 11:04 PM
I hear that! ^^
Old 04-16-2011, 05:34 PM
ls1player's Avatar
I am dropping these bad boys into my Orange C5 with an aps kit.
I will let everyone know the results.
I couldn't use the same compressor side as the turbo's pictured above in the earlier post.
Adam
Old 04-16-2011, 06:09 PM
Adam
Nice, Adam!
I kept an eye on your power numbers when I was building mine my APS C5. I've got some cool things in the works now.
Old 04-17-2011, 09:03 AM
lsx1's Avatar
I also preordered,will be putting these on my 428ls7.
Quick Reply: APS turbo upgrade
