spark plug boot end options? wires won't fit right
hey guys have a small problem here with spark plug wire options. i have a set of custom headers from virginia speed and there is not much room to work with. this is a 6.0 motor with coils in stock location. the truck wires are to long a spark plug end and cant fit. i tried the msd multi angle ones and they dont fit as well. i was thinking maybe the taylor 90 degree end ones as they look like a shorter boot to fit and then i can just bend wire up out of way. is there any custom kits with short boots for the sprak plug ends. i wish the spark plug end was as small as the coil end. here is a pic of what im working with if anyone has any ideas on what wires i can use.
Most of the 90's won't fit. They are turned too tight.
Check out the MSD 45* Orange silicone hight temp universal boots.
I have less room than you with upside down truck manifolds. And I'm using these just fine.
Here is a picture of the same headers with MSD-32139 LT1 Universal wires. The wires are close, but have lasted longer than I thought they might. I will probably end up moving the coils under the headers.
hbhc do you have any other shots of the routing of them i may go this route and want to see how you did it. also taht lt1 universal kit you bought did you have to buy any other ends for them or is that kit having everything? thanks for any info
Scott
yeah i noticed that the coils are closer but i can always move the bracket up a little on the valve cover by slotting the holes some. im really out of options and this is looking like my best solution along with some heat shields for the wires.
I like your setup, do you have more pictures or a build thread?
