Copper Head Gasket O-rings
What is the best way to set up the Stainless Steel Orings when running a 40 thou thick copper head gasket, iron block and alloy heads.
- Single Oring in Block and no reciever groove in Head.
- Single Oring in Block and reciever groove in Head.
What other options are there ? Double O Rings ?
Thanks
Thanks
The BEST way would be to do double O-rings coupled with double receiver grooves. But that can get pricey for all that machine work.
I personally run O-ringed iron block with no receiver grooves in alloy head making 100whp per cylinder with no blow outs. I also have 5 studs per cylinder also though, as apposed to the typical 4 on the LSX engines.
I have been told that once you compress a copper gasket onto an O-ringed block/head, you cannot use that gasket again. I have also heard of people doing it with no ill results though, so... whatever.
7 Second Club
Thanks
Thanks
Not sure if you are jesting or not (hence the jester). However, when talking about head gasket sealing, then HP per cylinder is a HUGE deal. If you had a one cylinder making 100whp or an eight cylinder making 800whp, both head gaskets are going to have very similar stresses they have to contend with.
The reason I mentioned 5 studs per cylinder vs. 4 should be obvious. More studs = less chance of lifting a head.
OWN3D BY MY PROF!
On the doube O ring are both the receiver grooves in the head, block, or one in each? I could see the advantages of having more of a seal, but is the pressure exceeding the first seal?
EDIT: Just started looking into this more. How many people are driving around with an O ringed block, grooved head, and copper head gasket? Is it sealing everything that it should; oil, combustion, coolant?
Phil, I remember reading a post you made a while ago about using a tool versus a CNC machine to cut the grooves. I was just looking at the BHJ tool and found quite a few instances of it being used. In your experience were you having issues caused by the tool or was the CNC simply more precise?
Double o rings we use are, ....o ring in head, and o ring in block
They are stacked, ontop of each other.
Slightly thicker copper gasket used to grip
Strongest method
Strongest method
