Turbo + Nitrous nozzle or DP?
Old 09-13-2011, 11:00 AM
AutomagicLS1's Avatar
Default Turbo + Nitrous nozzle or DP?
I'm looking to add a 125-150 shot to my car for the track. What are you guys doing for a nitrous setup that won't be used much. Is a nozzle safe with that shot with boost?
Old 09-13-2011, 07:00 PM
camaro383's Avatar
i would run a dry shot, that what i plan on doing.. but how would the ecu know to add more fuel when spraying without a maf sensor.. since thats how a dry kit works.. maybe you need a wet kit when running sd, lol wut do i know
Old 09-13-2011, 08:16 PM
yelo04goat's Avatar
in for info.
Old 09-13-2011, 10:09 PM
Fbodyjunkie06's Avatar
I think it would do it by ignition timing, i.e. pulling more timing via a wot switch when the nitrous is activated than adding more fuel via pe or fuel enrichment.
Old 09-14-2011, 04:48 PM
Johnv's Avatar
A wet setup would be far easier to tune, and won't need anymore injector capacity, but you will need enough fuel pump or a stand alone pump for the nitrous.
A mate runs a 75 shot using nozzels on his Turbo (13psi boost) and its pretty insane.
a 75 shot with boost will give similar results to 100 shot NA .
For a 125/150 shot i would run a plate for better distribution, and you may want to look at a progressive controller to help it hook up, cause its gonna hit hard with boost.
Old 09-14-2011, 05:12 PM
I also don't think you need a 100-150 shot unless your just looking for all out insanity. If you are just trying to spool the turbo faster or get out of the hole harder a 50-75 dry shot would work fine, and I would think with a dry shot you could just retard the timing by 2-4*'s via a window switch, or if you are using EFIlive I know they have a custom os that allows seperate power adder fueling tables and timing tables that are seperate from the main base tables.
Old 09-15-2011, 02:25 AM
chuntington101's Avatar
bingo! i have heard that running N2O on a boosted motor is effectively like running 150-200% of the N2O you are spraying. the extra power is thanks to the cooling effect of the N2O as it phase changes from liquid to a gas and than the preusre drop from 950psi down to whatever you intake preusre is.
Chris.
Old 09-15-2011, 03:18 PM
MaxxMitchell's Avatar
Nozzel should be fine, but will need to watch fuel pressure as you are close to the edge.
Quick Reply: Turbo + Nitrous nozzle or DP?
