Impressive A&A kit + Meth results
Old 10-13-2011, 12:00 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
Default Impressive A&A kit + Meth results
Car: 02 z06
mods: A&A si trim supercharger kit w/ 3.6" pulley 11psi Peak boost, Cooling Mist CMGS methanol injection kit, Relocated IAT behind Throttle body. all else completely stock!!!
Results: 600.4 RWHP 505.3 RWTQ, 11 timing at peak boost with meth off, 14 degrees with meth on...
video:
http://www.youtube.com/watch?v=kWG23FtCFVs
Old 10-13-2011, 12:19 AM
chevellepowered's Avatar
nice results.. thinking im going meth now..instead of n2o..
Old 10-13-2011, 12:39 AM
20TA02's Avatar
those are really good numbers...
Mike convinced me to relocate IAT behind throttle body on my car... hopefully it does as good as this vette.
Old 10-13-2011, 08:46 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
It allows me to only add timing via the iat spark table therefore if it fails you don't have all that added timing...
Old 10-13-2011, 09:18 AM
20TA02's Avatar
thats what he was explaining to me and it makes sense...
Old 10-13-2011, 11:54 AM
Larry @ AMS's Avatar
Those are some good #'s for the mentioned combo.
Old 10-13-2011, 02:38 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i wasnt expecting it honestly... but then again its making 11 lbs of boost
Old 10-13-2011, 09:46 PM
Fbodyjunkie06's Avatar
I think I am going to relocate my IAT to the same spot, and do the same thing you guys are doing with adding and subtracting timing with the IAT table in HPT.
Old 10-14-2011, 02:25 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i feel its a little safer way to go
Old 10-14-2011, 11:16 PM
got-a-ls1's Avatar
can someone explain moving the iat sensor? trying to see what difference it would make behind the throttle body as opposed to in a charge pipe...? i understand the IAT sensors in MAF's are slow to respond but what advantage in a regular iat sensor?
Old 10-15-2011, 10:08 AM
Louis's Avatar
When the meth fails, IATs climb, timing is pulled. Engine is saved.
Old 10-15-2011, 10:24 AM
No Juice's Avatar
Then why not place the IAT between the throttle body and meth nozzle? Won't that achieve the same thing?
Old 10-15-2011, 06:46 PM
Louis's Avatar
Thats the intent.
If you have a 5 wire MAF, you need to separate the MAF from the IAT. Spraying meth over the MAF will cause a major rich state.
MAF>Meth>IAT>TB
Old 10-15-2011, 07:09 PM
liqidvenom's Avatar
so to understand are you undoing the maf harness and then installing a IAT sensor near the TB?
Old 10-15-2011, 08:49 PM
got-a-ls1's Avatar
understand that exactly... so is this just a big deal for guys running mafs? if your speed density already does it matter where the iat is as long as it is downstream of the meth? cant see any other advantages being behind the throttle body expect with a maf? unless im missing something?
Quick Reply: Impressive A&A kit + Meth results
