Front mount turbo with a/c almost complete PICS
Old 10-19-2011, 05:25 AM
ZTwentyAteU's Avatar
Default Front mount turbo with a/c almost complete PICS
I've been working on this 01 trans am, was a heads/cam nitrous car.car already had bmr everything(uppers n lowers, k member, rear everything bmr, 12 bolt, everything you can do to a t56. I've done a front mount 76 kit using a slightly modified ebay/ptk hotside and lots of ebay parts. This car retains a/c, only thing it dont have now is front sway bar
forged piston/rod/stock crank ls1 (stock c.i.)
fast 92
stock 317s
cometics, ARP studs all over...head studs, main studs, hell it has header studs
modular turbo alt relocation
ball bearing 76 w/.96a/r hotside (on3)
44mm vband wastegate (on3)
EMUSA billet vband BOV
universal FMIC and 3in piping kit
eboost 2 controller
return through evap line fuel setup
60lb injectors
twin 255 pumps
12in pusher and 10in puller fans
lots of header wrap
all new precision turbo vband clamps since the ebay ones SUCK
after many aggrevating hours, its nearing completion. I'll kep yall updated
Old 10-19-2011, 06:51 AM
gi8e7oi825's Avatar
Originally Posted by ZTwentyAteU
I'm confused by what's going on in this picture... my initial thought is it's plumbed wrong, but your fuel lines might be routed differently than I'm assuming.
Old 10-19-2011, 07:41 AM
narx66gmc's Avatar
Great job!! What headers r those?
Old 10-19-2011, 07:55 AM
gi8e7oi825's Avatar
On second thought, it seems fine, just not optimal for a FI application...
Old 10-19-2011, 08:35 AM
SPRAYED 01's Avatar
Awesome build looks great. One thing I can tell you is those fans will be enough to run your ac in town. Might be okay on the highway though.
Old 10-19-2011, 09:18 AM
armyboyatc's Avatar
Also curious about the headers and exhaust pieces used.
Old 10-19-2011, 09:46 AM
merim123's Avatar
he said in the original post he's using the EBAY turbo kit. He's just wrapped it all and used different V-band clamps.
OP - why can't you run a swaybar?
Old 10-19-2011, 09:52 AM
You are correct the way the regulator is setup is not optimal for boost, *EDIT I changed it around*
Guys, the headers are from the ebay hotside kit. I simply made some changes on the crossover pipe and the downpipe which had to be snaked around the k member, and bought some good v band clamps to replace the ones that come in the kit.
I have my fingers crossed on the fans, the puller does 1200cfm and the pusher does 1400. If it dont work I can still stuff another fan on it.
Old 10-19-2011, 09:56 AM
If I really really wanted to, the sway bar could be put back on, but I took the bracket off for it on drivers side to clear the downpipe. Unfortunately this kit is not made for a BMR non turbo k member. Look right above the drivers side tie rod and you can see what I mean about sway bar interference
Old 10-20-2011, 01:51 AM
I changed the fuel lines. I'm not really sure what I was thinking at the time...it worked but was not good, could deadhead the pass rail the other way. Oh well 5 minutes and here it is.
Old 10-20-2011, 02:43 AM
twins in the bucket
Old 11-05-2011, 05:21 AM
Formula1RR's Avatar
any updates?
Old 11-05-2011, 08:18 AM
evo462's Avatar
These pushers flow 2,210 CFM each. I will be blowing through a condenser as well, using these fans.
http://www.summitracing.com/parts/DER-16925/
Old 03-14-2012, 10:21 PM
silver1r's Avatar
Any updates?
Old 03-14-2012, 10:54 PM
k_cash1432's Avatar
twins in the bucket
Holy ****, somebody acculy using high pressure fuel line clamps...
Old 03-14-2012, 11:41 PM
Burken01's Avatar
Im doing a similar setup and was thinking of the TU1 cam with my 317 heads, which cam are you running.. also whats your compression at?
thanks, and I'm subscribing
Old 03-15-2012, 12:09 AM
flippincamaro's Avatar
Car got on fire from a faulty fuel/oil line. James ztwenty8u is/has been parting it out. Pm him he might still have some parts
Old 03-15-2012, 12:15 AM
Burken01's Avatar
ok i pm'd him, did he have a ad up about parting it out.. or just hearsay?
Old 03-17-2012, 11:02 PM
i believe he had a ad up before.
Old 03-17-2012, 11:05 PM
Burken01's Avatar
thanks, i pm'd him..
Quick Reply: Front mount turbo with a/c almost complete PICS
