LS6 vs LS9 cam for S475 turbo LQ9?
I ran 6.73 @ 103 and that's at 3950 lbs,,,if your in a 3k fox...well you'll easily go faster
i would ideally like to see something in the 6.2x range when it's all together or possibly faster.
Restricted User
What's the worst that can happen? Put the kit together, run it as is and make some pulls on the dyno or at the track. If you don't think that it's working right at that time, you'll atleast have data to compare against once you switch to which ever other cam at that time. It's not like swapping a cam is the end of the world as long as you already have the springs installed.
research is fun!
went to the track tonight, ran a handful of 7.0's before a belt slippage problem finally got so bad i had to call it a night and drive home before she left me stranded.
[youtube]bsZ58J4HRro[/youtube]
so you guys think the tsunami might actually be a decent turbo cam?
