Deck height with 6.125 rod
Old 11-17-2011, 10:19 AM
turbo6man's Avatar
Default Deck height with 6.125 rod
Hi I am getting ready to purchase my rods and pistons for my turbo lq4 build and I was on the Wiesco website looking at the K444X3 piston. It states that a lq4 block has a deck height of 9.230 and that piston with a 6.125 rod has a zero deck height of 9.236 which means the piston will come out of the bore by .006 Is this ok? What is the max acceptable range? Also if I need to re surface the deck of the block during machining the piston will come out of the bore even more. Thanks
Old 11-17-2011, 11:13 AM
killernoodle's Avatar
Compressed head gasket thickness is probably more than .040", so it should be fine.
Old 11-17-2011, 10:07 PM
JRENIGAR's Avatar
I think factory ls1 pistons are about .020" out so you should be good. I personally would not want any piston out of the bore on a FI app but thats just me.
Quick Reply: Deck height with 6.125 rod
