Harmonic Balancer
Harmonic Balancer
I need help. I have an 02 SS with the Vortech Supercharger on it. The threads on the crank stripped out where the balancer sits. I already got everything together but need a new balancer. I see that the superchargers pully is bolted to the balancer and I need to know what is the right balancer for this setup. ATI told me to get #918853, but I want to know if there are other balancers that will work. Is there an underdrive ballancer? How about belts?
Thanks,
Thanks,
Thanks,
Thanks,
I've replaced the crank but the balance is all loose. It was spinning on the end of the crank when I was on the highway for about 5 minutes. It's all worn out in the middle.
I'm using a Powerbond with my setup PB1480-SS. No idea how your blower drive mounts though as to whether it would be suitable.
And yours should be either pinned or keyed if it's driving a blower. Do not rely on the interference fit only.
Does anyone know if this will also work with procharger crank pulleys? These are about half the price of an ATI dampener.
After another request.
The PB pulley I am using has 6 x 3/8" UNF bolt holes. These are on approx 81mm PCD ( 3.2" )
From this you can approximate the centre hole if this is used for location. I'm guessing at around 2.7", but can measure if required.
I dual pinned mine. Ignore the trigger wheel mounted on the rear. Ive done this for my ecu. It does not come with that installed.
Uploaded with ImageShack.us
Well I just ordered the ATI balancer along with the pinning kit. Thanks Stevieturbo for the whole pinning of the balancer. I didn't realize that they need to be pinned. I bought the car like as it is, with out it pinned.
This thread got me to thinking and I have been doing a little investigation and research on the powerbond balancers. It looks like SDCE and Procharger use the same crank pulley's (diameters are different but they mount the same). Also ATI balancer and power bond have the same bolt pattern for the pulleys.
Everyone says you have to use and ATI balancer but it looks like Powerbond will also work and I'm betting other brands will as well. This is good to know to have other options, as it would be nice to get an under driven balancer while spending the money.
ATI told me the bolt circle is 3.2" and also been told from someone that the sdce bracket (works with ati) is 2.75" from bolt to bolt. Stevieturbo confirmed his powerbond also has the same measurements for bolt spacing.
It would make sense that they do use the same fitments. As certainly my PB isnt intended for a single application.
Having 6 bolts also has to be better than only 3. And it's a plain and simple steel design.
I would have no interest in an underdrive pulley, and really cannot see the point of them unless you are turning very high rpm's or running high rpm's for extended periods.
For a road or drag car, underdrive is a total waste of money IMO.
I am also curious to know if the Powerbond damper would work with a procharger cog. I would like the additional 3 bolts that this offers along with the savings in price. Have waited awhile to pickup the ATI 918853 in hopes that one would come across used. Has anyone used the Powerbond one with a procharger cog????
Googling your part number, there is an obvious difference.
The ATI seems to have a flush face where any extra pulleys might bolt to ?
Obviously my power bond centre is recessed. And there is a large spacer before the blower pulley can be bolted.
No big deal. You just make a spacer to mount your blower pulley where you need it.
thank you for the help stevieturbo. What type of crank pulley are you using?
If the original poster is running a vortech kit with I assume vortech's pulley, and it fits an ATI balancer, then i would thing they would all be interchangeable. Like you said might have to fab something up to get the spacing correct but the bolts will line up. Did your pulley require a spacer to bolt to the power bond, or how did it fit and bolt up? I am assuming you are running a vortech kit?
I wonder if i could simply buy a powerbond balancer and a 8rib crank pulley for a vortech kit? then make sure the sdce bracket is all lined up and should be good.
thanks again for the help!
I'm confused, you actually have a powerbond pulley driving your supercharger? Is it bolted to your power bond balancer?
You put pictures up of the balancer, but not how you are bolting the supercharger crank pulley to the balancer, or the crank pulley by itself.
The parts you see above were bought from CAPA in Australia as part of their kit for their LS/Vortech cars.
Although I'm using different pulleys now. But I am still using the powerbond and the steel spacer.
It would be easy for any machine shop to make the spacer up anyway.
