Turbo for a 364ci lq9/4? is this one ok?
Looking for a turbo that would be great for 364ci lq9/4 single turbo build. First time stepping into the turbo world and need a little help.
Found a Garrett gt55 with:
Inducer 84 mm.
Exducer 118 mm
1.37 A/R
T-6 divided
How does this turbo sound? What would you recommend?
Goals for this build are 1000rwhp...street driven on weekends, with occasional track. This will be a build using truck manifolds, ls6 intake and my tfs 235's. Looking into possibly using a Virginia Speed V3 turbo cam 23x-23x .61x-.60x (not sure yet). Compression will be around 9:1 (should i go a little higher?) and I'll run e85 for fuel. Thanks ahead of time for the help fellas!
Inducer 84 mm.
Exducer 118 mm
1.37 A/R
T-6 divided
