30th Anniversary 370 Turbo Build
Old 02-15-2012, 11:42 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Nice looking project. Good luck with it.
Old 02-15-2012, 12:48 PM
rossi89's Avatar
Thanks
Old 02-22-2012, 10:21 PM
rossi89's Avatar
Here are a couple updates...
Notched out for the vertical radiator.
Used bondo to smooth it out.
Painted the engine bay.
Old 02-24-2012, 10:17 PM
zxgto06's Avatar
Looks really good..
Old 02-25-2012, 12:33 AM
mpatton's Avatar
What did u use to paint your bay? Also how bright is it, doesn't look as bright as I was thinking it would. Reason I ask is im getting ready to spray my bay and mines white also. GL with the build.
Old 02-25-2012, 10:08 AM
rossi89's Avatar
It looks brighter in person. It matches the outside paint of the car with the same brightness. I just used spray paint. 2 coats primer, 3 coats Dupli-Color Artic White paint, and two coats clear. Here is a picture that looks a little brighter...
Old 03-03-2012, 09:36 PM
Stippy17's Avatar
Good build so far bud. I can't wait to see more progress.
Glad the rack and linkage I sold you will be put to good use! Lol
Old 03-04-2012, 06:50 AM
rossi89's Avatar
Thanks man. Glad to see someone in my area that works with f-bodys. I'll stop by when it's all done.
Old 11-13-2012, 10:09 AM
rossi89's Avatar
Finally back at it! I put my deposit down on the Huron Speed Truck Manifold Kit. The group purchase deal was too good to pass up. Here are some other new updates...
Bottom end ready to go.
I also picked up a turbo k-member even though I don't need one with the Huron Speed kit. It's always nice to free up some space.
Pa Racing Turbo Kmember
Old 11-13-2012, 04:02 PM
RacerXLs1's Avatar
Man I forgot about this build, what turbo were you going with.
Old 11-13-2012, 04:44 PM
rossi89's Avatar
Yea it's been a while. I am finally able to start back up on the build. I actually just ordered the new Billet Turbonetics 7675 .96a/r today. They should be shipping it out in a few weeks.
Old 01-01-2013, 09:34 PM
  #32
coolmanvette75's Avatar
Glad to see I am not the only one doing the HS kit in an LT1 car. Looks like a fun project man!
Old 01-01-2013, 09:41 PM
  #33
Camaro9969's Avatar
Nice car you will love that Tu2 cam trust me
Old 01-01-2013, 09:45 PM
  #34
LS1Tech Sponsor
Superman09's Avatar
Nice to see it coming together, looking forward to this build! Thanks again for your support and let me know if there is anything else you need!
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 01-02-2013, 10:58 PM
  #35
rossi89's Avatar
Thanks guys
Old 02-13-2015, 05:56 AM
  #36
rossi89's Avatar
It's been forever, but here is how the car sits right now. The car was put on hold for a while due to starting a new job, moving, and getting married. There will be more updates in the near future.
Old 02-17-2015, 02:45 PM
  #37
rossi89's Avatar
I found this on my phone from when the motor was going in the car. If anyone missed it earlier, it is a 370 with a TU2 cam, Diamond 16cc pistons, Compstar rods, and stock crank. I am running 317 heads that were checked over and assembled with BTR dual springs and Manley SS valves.
Old 02-17-2015, 02:58 PM
  #38
rossi89's Avatar
I also have a couple updates....
I made a radiator cover.
I started on the fuel system. Here is the Y block that is going to feed the back of my rails.
I ran into a problem with the alternator relocation being very close to the fuel rails. I solved the problem by running a 90 off the rail and notching some of the plastic cover on the back of the alternator.
Here you can see where the plastic cover was notched.
Old 02-17-2015, 03:06 PM
  #39
IronBlocked's Avatar
It's going really nice man! Hope to see it run
Old 02-17-2015, 04:55 PM
  #40
Meth Sled's Avatar
What're you doing about a fuel regulator? Good looking build so far!
Quick Reply: 30th Anniversary 370 Turbo Build
