LQ4 S480 Build
Next time I suggest using a cherry picker for lifting the car.. that jack/wood method looks sketchy. Looking forward to your progress! plans of going the truck manifold route or tubular?
Ya if i had a lift i would of pulled it up with that but we were very careful its not going anywhere. Truck manifold for now and i have a guy whos going to build some headers for me and do all the welding including the cage. He wants to get his name out there and is damn good. I need to wait for my trans then i'll throw the lq4 in
The following users liked this post:
Broon72 (08-10-2020)
holly crap thats huge i was thinkin about doin a rear mount (that way if it sucked i could take it off) on my 402 car with one of those but it may not fit lol. good luck with the build ill be watchin
[QUOTE=Camaro9969;16003523]What are you building
stock short block lq4, l92 heads . unsure of cam and valve springs. i got a killer deal on a used s480 and a th400. i need a new convertor and change gears in my 9inch.
So have torn the lq4 apart and its nasty i have some pictures but its a mess i'll be cleaning it up and two bolts are broken off in the head from the manifold....gotta be something annoying of cours. Anyways i bought some katech rod bolts and am going with arp or katech for the head studs. I want a cam just trying to figure out what size i should get fbodyjunkie has been helping.....What else should i get some springs and pushrods??? i dont want to go do crazy on this motor just some little things to wake the motor up before i add the turbo on it. Or should i just do the rod bolts and go for it
Little more progress made waiting for parts to come in to put it all back together..... Bought a TU2 236 236 .587 .587 112.5 Cam from Speed Inc..(thanks FBodyJunkie for the help) Pushrods, Lunati Double Spring kit, LS9 Gaskets, SLP Double Timing Chain, SLP Oil Pump, ARP Head Bolts and Rod bolts getting them resized right now had a couple issues.... Then Going in to start it up and mock the piping.....
