4.8 or 5.3 pistons?
Old 03-14-2012, 09:23 PM
a4ls2goat's Avatar
Default 4.8 or 5.3 pistons?
trying to figure out if this is a 5.3 or 4.8.
flat top pistons with a cross in the middle
Old 03-14-2012, 09:37 PM
pwrtrip75's Avatar
Measure the bore and stroke... Doubt you'll be able to tell by casting patterns.
Old 03-14-2012, 09:42 PM
a4ls2goat's Avatar
so is there 5.3s with flat top pistons?
Old 03-14-2012, 09:46 PM
got-a-ls1's Avatar
as far as i know only l33's came with the flat tops in a 5.3 which is an aluminum block. havnt researched it though. They do share the same compression height and bore size though and are all interchangeable.
Old 03-14-2012, 10:36 PM
Vents's Avatar
Looks 4.8. Find BDC and put a tape measure down the hole. 3.6" = 5.3l. 3.2"=4.8. want to sell those pistons?
Old 03-14-2012, 11:02 PM
a4ls2goat's Avatar
lol.
i just got this motor for my car..so either its a 4.8 or 5.3 im still gona use it.
ill be putting the ls9 headgaskets for safety. will this lower compression some?
Old 03-14-2012, 11:15 PM
tripblackls1's Avatar
The conversion section has a sticky on 4.8/5.3 info
Old 03-15-2012, 05:26 AM
BottleFedZ346's Avatar
Does it not say on the back of the block?
Old 03-15-2012, 07:48 AM
a4ls2goat's Avatar
All 5.3s and 4.8 say " 4.8 / 5.3"
Old 03-15-2012, 08:27 AM
Vents's Avatar
Originally Posted by a4ls2goat
lol.
You want lower compression? I've got a set of dished pistons for ya. Straight trade?
Old 03-15-2012, 08:41 AM
a4ls2goat's Avatar
Lol.. nah man. I don't wana touch the short block. I wana see how far I can push it.
Old 03-15-2012, 12:53 PM
Strokinit383's Avatar
flat tops = 4.8, dished pistons = 5.3
Old 03-15-2012, 02:07 PM
projectcam's Avatar
Did you hurt the motor in your car already Hector?
Old 03-15-2012, 02:13 PM
a4ls2goat's Avatar
I pulled my ls2 to put forged internals.. that's it.. pulled it before it did mess up. Haha.
Old 03-15-2012, 02:58 PM
projectcam's Avatar
Smart if you did. I don't think many people will believe you though. Make sure your tuner keeps the timing very conservative with these stock bottom ends your using. They will stay alive and make power but will f*ck up alot of your parts when they go.
Old 03-15-2012, 03:59 PM
Im leaning to beleive it's a L33, when i had mine the pistons were flat top's and the cross....
Old 03-15-2012, 06:00 PM
silver_82's Avatar
L33's are aluminum, that block is clearly iron. Measure the stroke as people are saying to find out if its a 4.8
Old 03-15-2012, 08:39 PM
a4ls2goat's Avatar
Really? I can give a **** if people believe me..
The car was tuned on 10 degrees of timing on the ls2. Than I said **** it, I'll pull the ls2 and put a JY motor in while I forge the ls2. Plain and simple.
Old 03-15-2012, 08:41 PM
a4ls2goat's Avatar
I do believe the 4.8 pistons are the same ones as the l33
Old 03-15-2012, 11:02 PM
silver_82's Avatar
Right, i believe they use the same pistons, but he said he believes it may be an l33. Was stating that an l33 is an aluminum 5.3 and that tbe block in the pic looks to be iron.
Did u measure the stroke?
Quick Reply: 4.8 or 5.3 pistons?
