Is my belt too loose? F1R video content inside
I recently acquired a 3-series BMW with a F1R-procharged 410 ci SBC transplanted inside. The car does not feel all that fast, and though I have no boost gauge hooked up, I have a feeling belt slip is the culprit. I took a video of the movement of the belt. Can I get a confirmation that the belt is WAY too loose? The crank pulley is 7" and the blower pulley is 4.25", so it should be turning 50,000 RPM at 5500 engine RPM at full tilt making some pretty good power.
Also, does someone sell an upgraded 12-rib tensioner that I could add to that bracket since the one on there looks kinda shot as is?
Link to video:
View My Video
Photo of engine bay:
Link to video:
View My Video
yes your belt is to loose, it should not be flopping around like that at idle,
you need to be careful though, the manual tensioner can put a **** ton of stress on the snout of that crank causing bearing issues or snapping the end of the crank off, if you crank down to hard on it.
you need to convert it to cog as the belts are the same width as the 12 rib it will fit everything you have already.
I have a 41 tooth blower pulley and a cog idler if you are wanting to switch.
pm if interested
pm if interested
LS1Tech Sponsor
pm if interested
pm if interested
Alan, that belt has slipped enough that I would start with a new belt. After the new belt has been installed, tighten it down tighter than you normally tighten a belt. Then take it easy on the new belt for about an hour to let it break in and stretch, then tighten it back down. I'd also wipe the blower off and keep an eye on it for signs of black dust appearing, which will tell you if the belt is slipping. A boost gauge would also help you to keep an eye on it.
Keeping an F-1R from slipping with a serpentine belt is going to be hard to do though, if you keep having belt slippage problems then I would convert it over to a cog belt as 9sectruck has suggested. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I agree, the belt is way too loose.
Also, the blower seems to make a good bit of noise when running. I'm sure some is normal and some might be from a loose bolt on the bracket that seems to serve no purpose other than rattle. However, when the car is off and I tap the belt next to the blower pulley, it makes a noise that seems to emanate from the inlet of the blower and out through the elbow and the filter.
Should I be concerned? Video below:
View My Video
Of course, the secondary question is that depending on how much work and cost that all is, what would be the cost to just convert to a cog setup?
The whistle sounds is normal. The grinding bearing sound isn't. I've run an F1R and F2 in the past and would highly recommend a 30mm cog drive. Your idler pulley should have a slot that allows you to loosen it and adjust the belt tension.
UNDER PRESSURE MOD
That tapping sound almost sounds like the lash between the gears. It's funny the way sounds can be amplified sometimes.
I have a D1 and it is pretty loud as well, but you get used to it. It's great for scaring away deer.
Here's what my car sounds like.
http://www.youtube.com/watch?v=zb2H-QL6NeQ
