problems with running a TVS1900 on milled heads?
Old 03-30-2012, 11:04 PM
GMH300's Avatar
Default problems with running a TVS1900 on milled heads?
So I've been told its not a good idea to run a supercharger with high compression. engine Can someone explain to me why this is? what problems it can cause?
I have a LS2 with LS3 rectangle heads which have been milled .030" which has my engine running at the standard LS2 10.9:1 compression ratio.
What issues would I have running a TVS1900 on this?
I see people running superchargers on the standard LS2 without any problems.
Thanks in advance for you help
Old 03-31-2012, 08:02 AM
LS1-IROC's Avatar
Lots of people run TVS blowers on high compression engines. GM even does it, that should tell you something.
Old 03-31-2012, 08:43 AM
dschmittie1's Avatar
People generally don't like to run high compression and boost. It makes the cylander pressure higher and can make it more pronned to detonation. You run a higher risk of popping a stock piston also. On a forged motor I wouldn't be worried about the higher compression
Old 03-31-2012, 10:56 PM
quicksilverado's Avatar
.030 is a lot of material to remove from a factory head. I would not push it to hard or lifting a head is in the near future.
Old 04-01-2012, 07:57 AM
redtan's Avatar
You won't have any issues, your comp ratio is not any higher than stock.
And it will take quite a bit of boost to lift the heads.
Old 04-04-2012, 06:48 AM
GMH300's Avatar
Thanks for all the responses.
I only plan on running a basic 5psi so shouldn't be any problems.
Quick Reply: problems with running a TVS1900 on milled heads?
