Can I use those N2O heads on my FI 408ci shortblock ?
I have new TEA/TFS 235cc that was setup for nitrous and I would like to use them in my boosted motor ..
- Milled to 66cc
- Some chamber work for better timing
- Lightweight LS3 valves turned down
- Modified exhaust valves for 50 degree seat
- N2O Exhaust port
- Powder metal guides to use stock rockers with comp turnion kit
What do you think ? lightweight valves are an issue ? N2O exhaust ports ?
- Milled to 66cc
- N2O Exhaust port
I don't see a problem there since many are using ls3/ls9/lsa heads on boosted application, all of those heads have light weight valves (I think). I see a problem there if the one who did the work doesn't know his **** in cylinder heads work.
I did my homework with piston to set the compression ratio around 9.5:1 SCR with 66cc heads, but I'm asking if light weight valve will be an issue or not as well as N2O exhaust port option in the heads
I would like to hear more opinions
